By tweaker
#26545 Got it running on my NodeMCU board. This project looks promising!
Already had Domoticz running so setting things up was actually "EASY" in my case.
Can i also use it to switch a relais from Domoticz?
By mvdbro
#26584
tweaker wrote:Can i also use it to switch a relais from Domoticz?
Redesigned the device configuration. It's now possible to have more than one sensor, pulscounter, switch, etc.
And devices are now linked directly to selectable GPIO pins.
There's also direct output control (without password requested) to drive relais, mosfets, etc.
It's very easy to use these http commands in Domoticz switch devices.
Sample Domoticz configuration screen print: (this is NOT the ESP you're looking at)
By danbicks
#26595 Wicked interface :)
Is this in standard IDE?
Would love a copy if you don't mind sharing.
Great work, nice to see the ESP web interface has some sparkle :)
Dans
By mvdbro
#26608
danbicks wrote:Wicked interface :)
Dans
I think that I put you on the wrong track here. The screenshot is not the ESP webinterface, but a sample of how devices can be configured within Domoticz towards the ESP Easy.
I changed my post to make this more clear.
I guess in the future when we have the spiffs storage running, we could design much more attractive web interfaces.
For now, just lean and mean classic html and no images...
