By Torah
#27286 Hi, lajolo
I changed your code for my use in the following way. But failed many times to send GET request. I can see that esp8266 connected wifi. BTW - not a module or home network issue. I've ran some piece of code doing the same stuff but using httpd. So from your experience, can you help out of this strange problem? Merci beaucoup.
the changed code is here:
// Import required libraries
// WiFi parameters
const char* ssid = "TorahYongquan";
const char* password = "PlantoWang";
// Host
const char* host = "planto.oicp.net";
// Start Serial
delay(10);
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
int value = 0;
Serial.println(host);
WiFiClient client;
const int httpPort = 80;
return;
client.print(String("GET /add.php?temper=22") + " HTTP/1.1\r\n" +
"Host: " + host + "\r\n" +
"Connection: close\r\n\r\n");
delay(10);
Serial.print("client.status(): ");
Serial.println(client.status());
Serial.print("client.available(): ");
Serial.println(client.available());
Serial.print("client.connected(): ");
Serial.println(client.connected());
while(client.available()){
String line = client.readStringUntil('\r\n');
Serial.print(line);
delay(5000);
lajolo wrote:That seems to work fine, thanks!
And I have left '\r' here:
Serial.print(line);
