By lajolo
#26391 Hello,
here is my source file.
I connect to www.example.com, but for the rest it is the WiFiClient example.
Thanks!
Marcello
// Import required libraries
// WiFi parameters
const char* ssid = "";
const char* password = "";
// Host
const char* host = "www.example.com";
// Start Serial
delay(10);
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
int value = 0;
Serial.println(host);
WiFiClient client;
const int httpPort = 80;
return;
client.print(String("GET /") + " HTTP/1.1\r\n" +
"Host: " + host + "\r\n" +
"Connection: close\r\n\r\n");
delay(10);
Serial.print("client.status(): ");
Serial.println(client.status());
Serial.print("client.available(): ");
Serial.println(client.available());
Serial.print("client.connected(): ");
Serial.println(client.connected());
while(client.connected()){
Serial.print(line);
delay(5000);
By martinayotte
#26395 The reason why it didn't originally worked is the fact that this "www.example.com" doesn't send an CR or CRLF, it is only sending LF ... ;)
So, putting back the available() is working if we are printing lines ending with LF
Code: Select allwhile(client.available()){
String line = client.readStringUntil('\n'); // <---- look for LF here instead of CR
Serial.print(line);
By torntrousers
#26410 Could it be that the response is being a bit slow so the code needs to first wait for it to be available? After the client.print try changing the delay(10) to this:
Code: Select all while(!client.available()){
    yield();
