By Thrinasco
#26987 Hi,
I am using the mesh network example given in the Arduino IDE hellomesh program.My target is to create mesh network for 3 or 4 ESP8266 modules should communicate with each other.
Does i need to dump the same program in all the nodes or there should be some other code for nodes.
#include <ESP8266WiFiMesh.h>
/* Create the mesh node object */
ESP8266WiFiMesh mesh_node = ESP8266WiFiMesh(ESP.getChipId(), manageRequest);
 * Callback for when other nodes send you data
 * @request The string received from another node in the mesh
 * @returns The string to send back to the other node
String manageRequest(String request)
   /* Print out received message */
   Serial.print("received: ");
   Serial.println(request);
   /* return a string to send back */
   return String("Hello world response.");
void setup()
   delay(10);
   Serial.println("Setting up mesh node...");
   /* Initialise the mesh node */
   mesh_node.begin();
void loop()
   /* Accept any incoming connections */
   mesh_node.acceptRequest();
   /* Scan for other nodes and send them a message */
   mesh_node.attemptScan("Hello world request.");
   delay(1000);
By Checco
#34289 Hello,
i use the ESP8266 module...
can i connect this module to create mesh network?
how i can conncet this module??
please give me more information..
thanks
F.N.
By haitao0612
#34477 mesh node:This mode is in AP+STA mode,have a server and client.The AP is Mesh_Node_ChipID,no pass. You can find zhe AP,and connect to it ,and TCP client of you device in STA model connect to Ip:192.168.4.1,port:4011,Ok!
you can find the define of Server and Client in the file "ESP8266MESH.cpp".
