By GengusKahn
#34213 This will use the Flash button to select the animation from the default Sample Sketch but also host an AP with a web page to select from some of the animations pre loaded with the library.
This includes some other web pages in the sketch I have left in to be reused...along with lots of extra declarations.....still loads of resources so re-use.....
Code: Select all/*//////////////////////////////////////////////////////////////////////////////////////////////////////////////////////
//        150KB free Sketch Space 31 KB free Memory and Untouched SPIFFS........
// This is a demonstration on how to use an input device & webpage to trigger changes on your neo pixels.
// You should wire a momentary push button to connect from ground to a digital IO pin(use the flash button).
// When you press the button it will change to a new pixel animation. Note that you need to press the
// button once or trigger from webpage to start the first animation!
 ___/'¬_         /\
{_-_ ^  \_______//
     \ _  _____  /
            _____
     _-_-_-_ *|* _-_-_-_
    -_-_-_-_-\@/-_-_-_-_-
_____________________________
#include "FS.h"
#include <Adafruit_NeoPixel.h>
const char* host = "EM-Pixels";
IPAddress apIP(192, 168, 4, 1);
WiFiServer server(80);
WiFiClient client;
extern "C"
#include "user_interface.h"
ADC_MODE(ADC_VCC);     //   !!*!*!*!*! DO NOT USE THIS IF LDR FITTED !*!*!*!*!*!!
//  Use this instead of ESP.getVcc() for modules with LDR Fitted, Alter Display Text from Volts!!!
//  This is the Start of the LDR Sensor Measurement Percent/10 Saturation of LDR
//  Keep the Scale relavant for Line Graph or select Different Axis.....(When Used)
delay(25);
int pfVcC = 10-(constrain(map((analogRead(A0)), 40, 900, 1, 10), 1, 10)) ;
delay(25);
//  This is the End of the LDR Sensor Measurement
int wloop=5;
char tDigit;
String TiMeS,TMnow,MyNtP;                            // The current TimeStamp from Google....
int tIMeh,tIMem,tIMes,newt,newt1,inChar,SCsa,MNsa,HRsa;
boolean got_text = false;   //Print the Text to LCD if true......
int hr,mn,st,st1;  // Uptime Duration Counter......
String DsTable;             //Discarded parts if the Strings......
String tmtxt1,tmtxt2,DisTeXt0,DisTeXt1;              //Strings from the Web....
String theDate,theDate1,duration1,theDateTr;             // The current TimeStamp Date from Google....
unsigned long ulMeasCount=0;                         // values already measured
unsigned long ulMeasDelta_ms;                        // distance to next meas time
unsigned long ulNextMeas_ms;                         // next meas time
unsigned long ulReqcount;                            // how often has a valid page been requested
unsigned long ulReconncount;                         // how often did we connect to WiFi
// The Flash Button fitted to GPIO 0 on most development modules can be used.
#define BUTTON_PIN   0    // Digital IO pin connected to the button.  This will be
                          // driven with a pull-up resistor so the switch should
                          // pull the pin to ground momentarily.  On a high -> low
                          // transition the button press logic will execute.
#define PIXEL_PIN    12    // Digital IO pin connected to the NeoPixels.
#define PIXEL_COUNT 40
// Parameter 1 = number of pixels in strip,  neopixel stick has 8
// Parameter 2 = pin number (most are valid)
// Parameter 3 = pixel type flags, add together as needed:
//   NEO_RGB     Pixels are wired for RGB bitstream
//   NEO_GRB     Pixels are wired for GRB bitstream, correct for neopixel stick
//   NEO_KHZ400  400 KHz bitstream (e.g. FLORA pixels)
//   NEO_KHZ800  800 KHz bitstream (e.g. High Density LED strip), correct for neopixel stick
Adafruit_NeoPixel strip = Adafruit_NeoPixel(PIXEL_COUNT, PIXEL_PIN, NEO_GRB + NEO_KHZ800);
bool oldState = HIGH;  // Switch
int showType = 0;
bool animate = false;  // Web Button
  WiFi.mode(WIFI_AP);
  WiFi.softAPConfig(apIP, apIP, IPAddress(255, 255, 255, 0));
  WiFi.softAP("Pixels http://192.168.4.1");    // Create WiFi network
  WiFi.begin();
  server.begin();
  pinMode(BUTTON_PIN, INPUT_PULLUP);
  strip.begin();
  strip.show(); // Initialize all pixels to 'off'
///////////////////////////////1
void wsysreset()
  //Perform challenge to user before getting here to reboot !!!
  //Make an attempt to send mail or other backup of log files then reboot
    ESP.restart();
// create HTTP 1.1 header
String MakeHTTPHeader(unsigned long ulLength)
  String sHeader;
  sHeader  = F("HTTP/1.1 200 OK\r\nContent-Length: ");
  sHeader += ulLength;
  sHeader += F("\r\nContent-Type: text/html\r\nConnection: close\r\n\r\n");
  return(sHeader);
// make html footer
String MakeHTTPFooter()
  String sResponse;
  sResponse  = F(" ");
  sResponse += F("<BR><BR><FONT SIZE=-1>ESP8266 With 40 WS2812B LED's<BR><FONT SIZE=-2>Compiled Using ver. 1.6.5-1160-gef26c5f, built on Sep 30, 2015</body></html>");
  return(sResponse);
//////////////////////////////////1
  // Get current button state.
  bool newState = digitalRead(BUTTON_PIN);
  // Check if state changed from high to low (button press).
  if ((newState == LOW && oldState == HIGH) || (animate == true)) {
    // Short delay to debounce button.
    delay(2);
    // Check if button is still low after debounce.
    if ((newState == LOW) || (animate == true)) {
      if (newState == LOW){
      showType++;
      if (showType > 9){
        showType=0;
//theaterChase(strip.Color(  0,   0, 127), 50); // Blue
      startShow(showType);
    if (animate == true){
   // Set the last button state to the old state.
      oldState = newState;
////////////////////////////////////////////////////////////////////////2
  if (!client)
    return;
  // Wait until the client sends some data
  unsigned long ultimeout = millis()+250;
  while(!client.available() && (millis()<ultimeout) )
    delay(1);
  if(millis()>ultimeout)
    return;
  String sRequest = client.readStringUntil('\r');
  client.flush();
  // stop client, if request is empty
  if(sRequest=="")
    client.stop();
    return;
  // get path; end of path is either space or ?
  // Syntax is e.g. GET /?show=1234 HTTP/1.1
  String sPath="",sParam="", sCmd="";
  String sGetstart="GET ";
  int iStart,iEndSpace,iEndQuest;
  iStart = sRequest.indexOf(sGetstart);
  if (iStart>=0)
    iStart+=+sGetstart.length();
    iEndSpace = sRequest.indexOf(" ",iStart);
    iEndQuest = sRequest.indexOf("?",iStart);
    // are there parameters?
    if(iEndSpace>0)
      if(iEndQuest>0)
        // there are parameters
        sPath  = sRequest.substring(iStart,iEndQuest);
        sParam = sRequest.substring(iEndQuest,iEndSpace);
      else
        // NO parameters
        sPath  = sRequest.substring(iStart,iEndSpace);
  // format the html response
  String sResponse,sResponse2,sHeader;
   if (sPath.startsWith("/pixel_inputs&LED"))
 if (sPath.startsWith("/pixel_inputs&LED3=0")) {
 showType=0;
 if (TMnow=="false"){
animate = true;
  TMnow="true";
    else if (sPath.startsWith("/pixel_inputs&LED3=1")) {
 showType=1;
animate = true;
    else if (sPath.startsWith("/pixel_inputs&LED3=2")) {
 showType=2;
animate = true;
    else if (sPath.startsWith("/pixel_inputs&LED3=3")) {
 showType=3;
animate = true;
    else if (sPath.startsWith("/pixel_inputs&LED3=4")) {
 showType=4;
animate = true;
    else if (sPath.startsWith("/pixel_inputs&LED3=5")) {
 showType=5;
animate = true;
    else if (sPath.startsWith("/pixel_inputs&LED3=6")) {
 showType=6;
animate = true;
    else if (sPath.startsWith("/pixel_inputs&LED3=7")) {
 showType=7;
animate = true;
    else if (sPath.startsWith("/pixel_inputs&LED3=8")) {
 showType=8;
animate = true;
    else if (sPath.startsWith("/pixel_inputs&LED3=9")) {
 showType=9;
animate = true;
  // format the html page for Pixel Input /
 if(sPath=="/")
    ulReqcount++;
    sResponse  = F("<html>\n<head>\n<title>Webpage NeoPixel Controller</title>\n</head>\n");
    sResponse += F("\n<script>\nfunction GetButton1()\n{\nnocache = \"&nocache=\" + Math.random() * 1000000;\nvar request = new XMLHttpRequest();\nrequest.open(\"GET\", \"pixel_inputs&LED3=0\" + nocache, true);\nrequest.send(null);\n}\nfunction GetButton2()\n{\nnocache = \"&nocache=\" + Math.random() * 1000000;\nvar request = new XMLHttpRequest();\nrequest.open(\"GET\", \"pixel_inputs&LED3=1\" + nocache, true);\nrequest.send(null);\n}\n");
    sResponse += F("\nfunction GetButton3()\n{\n\nnocache = \"&nocache=\" + Math.random() * 1000000;\nvar request = new XMLHttpRequest();\nrequest.open(\"GET\", \"pixel_inputs&LED3=2\" + nocache, true);\nrequest.send(null);\n}\nfunction GetButton4()\n{\nnocache = \"&nocache=\" + Math.random() * 1000000;\nvar request = new XMLHttpRequest();\nrequest.open(\"GET\", \"pixel_inputs&LED3=3\" + nocache, true);\nrequest.send(null);\n}\nfunction GetButton5()\n");
    sResponse += F("{\nnocache = \"&nocache=\" + Math.random() * 1000000;\nvar request = new XMLHttpRequest();\nrequest.open(\"GET\", \"pixel_inputs&LED3=4\" + nocache, true);\nrequest.send(null);\n}\nfunction GetButton6()\n{\nnocache = \"&nocache=\" + Math.random() * 1000000;\nvar request = new XMLHttpRequest();\nrequest.open(\"GET\", \"pixel_inputs&LED3=5\" + nocache, true);\nrequest.send(null);\n}\n");
    sResponse += F("\nfunction GetButton7()\n{\nnocache = \"&nocache=\" + Math.random() * 1000000;\nvar request = new XMLHttpRequest();\nrequest.open(\"GET\", \"pixel_inputs&LED3=6\" + nocache, true);\nrequest.send(null);\n}\nfunction GetButton8()\n{\nnocache = \"&nocache=\" + Math.random() * 1000000;\nvar request = new XMLHttpRequest();\nrequest.open(\"GET\", \"pixel_inputs&LED3=7\" + nocache, true);\nrequest.send(null);\n}\nfunction GetButton9()\n{\nnocache = \"&nocache=\" + Math.random() * 1000000;\nvar request = new XMLHttpRequest();\nrequest.open(\"GET\", \"pixel_inputs&LED3=8\" + nocache, true);\nrequest.send(null);\n}\n");
    sResponse += F("\nfunction GetButton10()\n{\nnocache = \"&nocache=\" + Math.random() * 1000000;\nvar request = new XMLHttpRequest();\nrequest.open(\"GET\", \"pixel_inputs&LED3=9\" + nocache, true);\nrequest.send(null);\n}\n</script>\n<body>\n<h1>NeoPixel Controller<BR>_________________</h1>\n<BR><BR><a href=\"/diag\">Diagnostics Information Page</a><BR>\n<body onload=\"GetESP8266IO()\">\n<h1><FONT SIZE=-1>Choose Animation of LED's</h1>\n<form id=\"txt_form\" name=\"frmText\">\n");
    sResponse += F("\n<button type=\"button\" id=\"LED3\" onclick=\"GetButton1()\">Pixels Set to OFF</button><br /><br />\n<button type=\"button\" id=\"LED3\" onclick=\"GetButton2()\">Pixels Red</button><br /><br />\n<button type=\"button\" id=\"LED3\" onclick=\"GetButton3()\">Pixels Green</button><br /><br />\n<button type=\"button\" id=\"LED3\" onclick=\"GetButton4()\">Pixels Blue</button><br /><br />\n<button type=\"button\" id=\"LED3\" onclick=\"GetButton5()\">Pixel Animation 4</button><br /><br />\n<button type=\"button\" id=\"LED3\" onclick=\"GetButton6()\">Pixel Animation 5</button><br />");
    sResponse2 = F("<br />\n<button type=\"button\" id=\"LED3\" onclick=\"GetButton7()\">Police Light</button><br /><br />\n<button type=\"button\" id=\"LED3\" onclick=\"GetButton8()\">Pixel Animation 7</button><br /><br />\n<button type=\"button\" id=\"LED3\" onclick=\"GetButton9()\">Pixel Animation 8</button><br /><br />\n<button type=\"button\" id=\"LED3\" onclick=\"GetButton10()\">Pixel Animation 9</button><br /><br />\n</form>\n<br />\n");
    sResponse2 += F("\n<font color=\"#000000\"><body bgcolor=\"#a0dFfe\"><meta name=\"viewport\" content=\"width=device-width, initial-scale=1.0, user-scalable=yes\"><BR>Animated Neopixels ANY TYPE !<BR>\n</div>\n<div style=\"clear:both;\"></div><p>\n");
    sResponse2 += MakeHTTPFooter().c_str();
        // Send the response to the client
    client.print(MakeHTTPHeader(sResponse.length()+sResponse2.length()).c_str());
    client.print(sResponse);
    client.print(sResponse2);
else if(sPath=="/yfireset")  // When Google time is used this will Sync the C
    ulReqcount++;
                                client.println("HTTP/1.1 200 OK");
                                client.println("Content-Type: text/html");
                                client.println("Connection: close");
                                client.println();
                                client.println("<!DOCTYPE HTML>");
                                client.print("<html><head><title>Webpage NeoPixel Controller</title></head><body>");
                                client.print("<font color=\"#000000\"><body bgcolor=\"#a0dFfe\">");
                                client.print("<meta name=\"viewport\" content=\"width=device-width, initial-scale=1.0, user-scalable=yes\">");
                                client.print("<h1>Webpage NeoPixel Controller<BR>WiFi Reset Page </h1><BR><a href=\"/graphic2\">Pressure Graph Page</a><BR><a href=\"/pressure\">Pressure Gauge Page</a>");
                                client.print("<BR><a href=\"/monitor\">Sensor Gauges Page</a><BR><a href=\"/graphic\">Sensor Graph Page</a><BR><a href=\"/table\">Sensor Datalog Page</a><BR><BR><BR><BR>Restarted WiFiConnections = ");
                                client.print(ulReconncount);
                                client.print("<BR><FONT SIZE=-2>environmental.monitor.log@gmail.com<BR><FONT SIZE=-2>ESP8266 With DHT11 & BMP180 Sensors<BR>");
                                client.print("<FONT SIZE=-2>Compiled Using ver. 1.6.5-1160-gef26c5f, built on Sep 30, 2015<BR>");
                                client.println("<IMG SRC=\"https://raw.githubusercontent.com/genguskahn/ESP8266-For-DUMMIES/master/SoC/DimmerDocs/organicw.gif\" WIDTH=\"250\" HEIGHT=\"151\" BORDER=\"1\"></body></html>");
  //WiFiStart();
  else if(sPath=="/diag")
     float   servolt1 = ESP.getVcc();
     long int spdcount = ESP.getCycleCount();
     delay(1);
     long int spdcount1 = ESP.getCycleCount();
     long int speedcnt = spdcount1-spdcount;
     FlashMode_t ideMode = ESP.getFlashChipMode();
     ulReqcount++;
                                String duration1 = " ";
                                int hr,mn,st;
                                st = millis() / 1000;
                                mn = st / 60;
                                hr = st / 3600;
                                st = st - mn * 60;
                                mn = mn - hr * 60;
                                if (hr<10) {duration1 += ("0");}
                                duration1 += (hr);
                                duration1 += (":");
                                if (mn<10) {duration1 += ("0");}
                                duration1 += (mn);
                                duration1 += (":");
                                if (st<10) {duration1 += ("0");}
                                duration1 += (st);
                                client.println();
                                client.print("<h1>Neopixel Control<BR>SDK Diagnostic Information</h1>");
                                client.print("<BR><a href=\"/\">Pixel Control Page</a><BR>");
                               String diagdat="";
                              //  diagdat+=ulReconncount;
                                diagdat+="<BR>  Web Page Requests = ";
                                diagdat+=ulReqcount;
                                diagdat+="<BR>  WiFi AP Hostname = ";
                                diagdat+=host;
                                diagdat+="<BR>  Free RAM = ";
                                client.print(diagdat);
                                client.print((uint32_t)system_get_free_heap_size()/1024);
                               // diagdat=" KBytes<BR>  Logged Sample Count = ";
                               // diagdat+=ulMeasCount;
                                diagdat=" KBytes<BR>  SDK Version = ";
                                diagdat+=ESP.getSdkVersion();
                                diagdat+="<BR>  Boot Version = ";
                                diagdat+=ESP.getBootVersion();
                                diagdat+="<BR>  Free Sketch Space  = ";
                                diagdat+=ESP.getFreeSketchSpace()/1024;
                                diagdat+=" KBytes<BR>  Sketch Size  = ";
                                diagdat+=ESP.getSketchSize()/1024;
                                diagdat+=" KBytes<BR>";
                                client.printf("  Flash Chip id = %08X\n", ESP.getFlashChipId());
                                client.print("<BR>");
                                client.printf("  Flash Chip Mode = %s\n", (ideMode == FM_QIO ? "QIO" : ideMode == FM_QOUT ? "QOUT" : ideMode == FM_DIO ? "DIO" : ideMode == FM_DOUT ? "DOUT" : "UNKNOWN"));
                                diagdat="<BR>  Flash Size By ID = ";
                                diagdat+=ESP.getFlashChipRealSize()/1024;
                                diagdat+=" KBytes<BR>  Flash Size (IDE) = ";
                                diagdat+=ESP.getFlashChipSize()/1024;
                                diagdat+=" KBytes<BR>  Flash Speed = ";
                                diagdat+=ESP.getFlashChipSpeed()/1000000;
                                diagdat+=" MHz<BR>  ESP8266 CPU Speed = ";
                                diagdat+=ESP.getCpuFreqMHz();
                                diagdat+=" MHz<BR>";
                                client.printf("  ESP8266 Chip id = %08X\n", ESP.getChipId());
                                diagdat="<BR>  System Instruction Cycles Per Second = ";
                                diagdat+=speedcnt*1000;
                                diagdat+="<BR>  Last System Restart Reason = ";
                                diagdat+=ESP.getResetInfo();
                                diagdat+="<BR>  System VCC = ";
                                diagdat+=servolt1/1000, 3;
                                diagdat+=" V <BR>  Datalog File Size in Bytes = N/A";
                                //diagdat+=Dfsize;
                                diagdat+="<BR>  System Uptime =";
                                diagdat+=duration1;
                                client.print("<BR><FONT SIZE=-2>environmental.monitor.log@gmail.com<BR><FONT SIZE=-2>ESP8266 With 40 WS2812B 5050 LED's<BR><FONT SIZE=-2>Compiled Using ver. 1.6.5-1160-gef26c5f, built on Sep 30, 2015<BR>");
                                diagdat = "";
                                duration1 = "";
   else if(sPath=="/srestart")
                                client.println();
                                client.print("<h1>Environment Monitor<BR>Please wait 10 Seconds......<BR><FONT SIZE=+2>System Reset Page !!!! </h1><BR><a href=\"/graphic2\">Pressure Graph Page</a><BR><a href=\"/pressure\">Pressure Gauge Page</a>");
                                client.print("<BR><a href=\"/monitor\">Sensor Gauges Page</a><BR><a href=\"/graphic\">Sensor Graph Page</a><BR><a href=\"/table\">Sensor Datalog Page</a><BR><a href=\"/diag\">Diagnostics Information Page</a><BR><a href=\"/\">Monitor LCD Text Input Page</a><BR><BR><BR><BR>Restarted WiFiConnections = ");
                                client.print("<BR><BR><BR><FONT SIZE=-2>environmental.monitor.log@gmail.com<BR><FONT SIZE=-2>ESP8266 With DHT11 & BMP180 Sensors<BR>");
client.stop();
wsysreset();
  else
// 404 for non-matching path
    sResponse="<html><head><title>404 Not Found</title></head><body><h1>Not Found</h1><p>The requested URL was not found on this server, What did you sk for?.</p></body></html>";
    ulReqcount++;
    sHeader  = F("HTTP/1.1 404 Not found\r\nContent-Length: ");
    sHeader += sResponse.length();
    client.print(sHeader);
  // and stop the client
  client.stop();
void startShow(int i) {
  switch(i){
    case 0: colorWipe(strip.Color(0, 0, 0), 50);    // Black/off
            animate = false;
            break;
    case 1: colorWipe(strip.Color(255, 0, 0), 50);  // Red
            break;
    case 2: colorWipe(strip.Color(0, 255, 0), 50);  // Green
            break;
    case 3: colorWipe(strip.Color(0, 0, 255), 50);  // Blue
            break;
    case 4: theaterChase(strip.Color(127, 127, 127), 50); // White
            break;
    case 5: theaterChase(strip.Color(127,   0,   0), 50); // Red
            break;
    case 6: theaterChase(strip.Color(  0,   0, 127), 50); // Blue
            break;
    case 7: rainbow(20);
            break;
    case 8: rainbowCycle(20);
            break;
    case 9: theaterChaseRainbow(50);
            break;
// Fill the dots one after the other with a color
void colorWipe(uint32_t c, uint8_t wait) {
  for(uint16_t i=0; i<strip.numPixels(); i++) {
    strip.setPixelColor(i, c);
    strip.show();
    delay(wait);
void rainbow(uint8_t wait) {
  uint16_t i, j;
  for(j=0; j<256; j++) {
    for(i=0; i<strip.numPixels(); i++) {
      strip.setPixelColor(i, Wheel((i+j) & 255));
    strip.show();
    delay(wait);
// Slightly different, this makes the rainbow equally distributed throughout
void rainbowCycle(uint8_t wait) {
  uint16_t i, j;
  for(j=0; j<256*5; j++) { // 5 cycles of all colors on wheel
    for(i=0; i< strip.numPixels(); i++) {
      strip.setPixelColor(i, Wheel(((i * 256 / strip.numPixels()) + j) & 255));
    strip.show();
    delay(wait);
//Theatre-style crawling lights.
void theaterChase(uint32_t c, uint8_t wait) {
  for (int j=0; j<10; j++) {  //do 10 cycles of chasing
    for (int q=0; q < 3; q++) {
      for (int i=0; i < strip.numPixels(); i=i+3) {
        strip.setPixelColor(i+q, c);    //turn every third pixel on
      strip.show();
      delay(wait);
        strip.setPixelColor(i+q, 0);        //turn every third pixel off
//Theatre-style crawling lights with rainbow effect
void theaterChaseRainbow(uint8_t wait) {
  for (int j=0; j < 256; j++) {     // cycle all 256 colors in the wheel
        strip.setPixelColor(i+q, Wheel( (i+j) % 255));    //turn every third pixel on
      strip.show();
      delay(wait);
// Input a value 0 to 255 to get a color value.
// The colours are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos) {
  WheelPos = 255 - WheelPos;
  if(WheelPos < 85) {
    return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
  if(WheelPos < 170) {
    WheelPos -= 85;
    return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
  WheelPos -= 170;
  return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
