By willbird
#34692 I'm running one of each right here on my desk, both are on ESP01's, using the same exact sketch just calling out the sensor differently, the DHT22 is showing about 10% higher RH than the DHT11. No filter caps on power input but I am running them on the dual voltage BB power supplies set on 3.3v so there is a cap on there I presume is a filter cap. Both have a 10k pull up resister on the GPIO that the DHT is on.
This is the Sketch I am using................
http://www.arduinesp.com/thingspeak
Bill
By picstart
#34819 This variation between sensors in the same position is troubling. When I have more time I will calibrate with a table salt solution that gives a fixed humidity of a reasonable range of temperatures...I'm hoping DHT22 or the DHT11 has an accurate value. If they don't it could be a commercial code library issue. I have DHT11 code for a PIC processor that agrees with humidity I get with the commercial code library for the DHT11. I suspect there is an issue with the commercial DHT22 code and the esp8266 Arduino IDE.
The DHT22 is consistent between DHT22's but is I believe way to high for RH.
