By Shlammod
#48843 Actually, the solution was quite simple (perhaps it had something to do with coding late at night and a good night sleep did the trick);
I switched my WiFi router off, so the ESP couldn't connect to it anymore. It booted to the default settings and presto; I was able to re-configure it.
By Manti
#49892 Question, did the filebrowser die because of an update or something?
I Just flashed my NodeMCU and where I could uploade files at first it now stops working (code breaks or something. If i refresh I get the webpage but no files show up.)
I did a new install so maybe its because of some updates. can someone verify?
greetings, Mark
By NailBuster
#61925 FYI...Wanted to just let you know that I re-worked this myWebServer to another project myWebServerAsync ....
https://github.com/nailbuster/myWebServerAsync
This is similar to myWebServer but now used the awesome ASYNC webserver as its base so that you get a non-blocking webserver that works a lot better with multiple requests and such.
I also embedded full jquery, bootstrap with css, and fontawesome within the server so they're available at boot/config...
I've been playing around with a full dashboard with jquery/boot/charts/gauges and it loads up quickly and is pretty stable....all running locally (no internet connection)
I have a compiled bin also if you just want to flash it to your esp8266 to test it out....copy the sample html files afterwards if you want to take a look at the stability...
