By athuldevin
#72935 #include <ESP8266WiFi.h>
#include <ESP8266WebServer.h>
extern "C" {
#include<user_interface.h>
/* configuration wifi */
const char *ssid = "COblaster";
ESP8266WebServer server(80);
void handleRoot() {
server.send(200, "text/html", "<h1>You are connected</h1>");
String addy = server.client().remoteIP().toString();
Serial.println(addy);
delay(1000);
Serial.print("Configuring access point...");
WiFi.softAP(ssid);
Serial.print("AP IP address: ");
Serial.println(myIP);
server.on("/", handleRoot);
server.begin();
server.handleClient();
delay(5000);
client_status();
delay(4000);
void client_status() {
unsigned char number_client;
struct station_info *stat_info;
struct ip_addr *IPaddress;
IPAddress address;
int i=1;
number_client= wifi_softap_get_station_num();
stat_info = wifi_softap_get_station_info();
Serial.print(" Total connected_client are = ");
Serial.println(number_client);
while (stat_info != NULL) {
IPaddress = &stat_info->ip;
address = IPaddress->addr;
Serial.print("client= ");
Serial.print(i);
Serial.print(" ip adress is = ");
Serial.print((address));
Serial.print(" with mac adress is = ");
Serial.print(stat_info->bssid[0],HEX);
Serial.print(stat_info->bssid[1],HEX);
Serial.print(stat_info->bssid[2],HEX);
Serial.print(stat_info->bssid[3],HEX);
Serial.print(stat_info->bssid[4],HEX);
Serial.print(stat_info->bssid[5],HEX);
stat_info = STAILQ_NEXT(stat_info, next);
i++;
} :roll:
