By simondid
#51245 so i found this circuit drawing witch seems to have a section called key witch describs a 470 ohm pull up on the nRST pin but also a resister called R3 0 (NC) with i think is the part thats not on the bord but somthing you can add how wut i calculate the r3 resistance?
By schufti
#51249 as I can't see what you foud, it is hard to judge.
But if there really is a 470 Ohm pull-up on rst, I would go for an other make....
470 Ohm as pull-up does not make any sense and no value for resistor to gpio16 would provide reliable operation.
