By martinayotte
#53859 It is there in "Generic", probably not on board specific, but you can add it by copy/paste menus in boards.txt, like I did for the Wemos-D1-Mini :
Code: Select alld1_mini.menu.Debug.Disabled=Disabled
d1_mini.menu.Debug.Disabled.build.debug_port=
d1_mini.menu.Debug.Serial=Serial
d1_mini.menu.Debug.Serial.build.debug_port=-DDEBUG_ESP_PORT=Serial
d1_mini.menu.Debug.Serial1=Serial1
d1_mini.menu.Debug.Serial1.build.debug_port=-DDEBUG_ESP_PORT=Serial1
d1_mini.menu.DebugLevel.None____=None
d1_mini.menu.DebugLevel.None____.build.debug_level=
d1_mini.menu.DebugLevel.Core____=Core
d1_mini.menu.DebugLevel.Core____.build.debug_level=-DDEBUG_ESP_CORE
d1_mini.menu.DebugLevel.SSL_____=Core + SSL
d1_mini.menu.DebugLevel.SSL_____.build.debug_level=-DDEBUG_ESP_CORE -DDEBUG_ESP_SSL
d1_mini.menu.DebugLevel.SSL_MEM_=Core + SSL + TLS Mem
d1_mini.menu.DebugLevel.SSL_MEM_.build.debug_level=-DDEBUG_ESP_CORE -DDEBUG_ESP_SSL -DDEBUG_TLS_MEM
d1_mini.menu.DebugLevel.WiFic___=Core + WiFi
d1_mini.menu.DebugLevel.WiFic___.build.debug_level=-DDEBUG_ESP_CORE -DDEBUG_ESP_WIFI
d1_mini.menu.DebugLevel.WiFi____=WiFi
d1_mini.menu.DebugLevel.WiFi____.build.debug_level=-DDEBUG_ESP_WIFI
d1_mini.menu.DebugLevel.HTTPClient=HTTPClient
d1_mini.menu.DebugLevel.HTTPClient.build.debug_level=-DDEBUG_ESP_HTTP_CLIENT
d1_mini.menu.DebugLevel.HTTPClient2=HTTPClient + SSL
d1_mini.menu.DebugLevel.HTTPClient2.build.debug_level=-DDEBUG_ESP_HTTP_CLIENT -DDEBUG_ESP_SSL
d1_mini.menu.DebugLevel.HTTPUpdate=HTTPUpdate
d1_mini.menu.DebugLevel.HTTPUpdate.build.debug_level=-DDEBUG_ESP_HTTP_UPDATE
d1_mini.menu.DebugLevel.HTTPUpdate2=HTTPClient + HTTPUpdate
d1_mini.menu.DebugLevel.HTTPUpdate2.build.debug_level=-DDEBUG_ESP_HTTP_UPDATE -DDEBUG_ESP_HTTP_UPDATE
d1_mini.menu.DebugLevel.HTTPUpdate3=HTTPClient + HTTPUpdate + Updater
d1_mini.menu.DebugLevel.HTTPUpdate3.build.debug_level=-DDEBUG_ESP_HTTP_UPDATE -DDEBUG_ESP_HTTP_UPDATE -DDEBUG_ESP_UPDATER
d1_mini.menu.DebugLevel.HTTPServer=HTTPServer
d1_mini.menu.DebugLevel.HTTPServer.build.debug_level=-DDEBUG_ESP_HTTP_SERVER
d1_mini.menu.DebugLevel.UPDATER=Updater
d1_mini.menu.DebugLevel.UPDATER.build.debug_level=-DDEBUG_ESP_UPDATER
d1_mini.menu.DebugLevel.OTA_____=OTA
d1_mini.menu.DebugLevel.OTA_____.build.debug_level=-DDEBUG_ESP_OTA
d1_mini.menu.DebugLevel.OTA2____=OTA + Updater
d1_mini.menu.DebugLevel.OTA2____.build.debug_level=-DDEBUG_ESP_OTA -DDEBUG_ESP_UPDATER
d1_mini.menu.DebugLevel.all_____=All
d1_mini.menu.DebugLevel.all_____.build.debug_level=-DDEBUG_ESP_CORE -DDEBUG_ESP_SSL -DDEBUG_ESP_WIFI -DDEBUG_ESP_HTTP_CLIENT -DDEBUG_ESP_HTTP_UPDATE -DDEBUG_ESP_HTTP_SERVER -DDEBUG_ESP_UPDATER -DDEBUG_ESP_OTA -DDEBUG_TLS_MEM
(Don't forget to restart IDE to make this effective.)
By Jep
#54064 Thanks martinayotte !
I was not aware menus could be customized through that file!
I can now see debug traces options for my NodeMCU board :D
