By Luiz Henrique
#56720
martinayotte wrote:Do you mean that the body is empty ?
Did you try to print it ?
Which framework are you using ?
Maybe String initialisation isn't done properly, do it that way instead :
Code: Select allString tratado = String(resposta);
I think this only Body is empty, i try to receive all data, and receive the headers, but the data don't receive.
I will try this and i edit.
By Luiz Henrique
#56722
Doesn't work using String tratado = String(resposta).
I use Node.js, my code in Node is:
Code: Select all//SendInfo to Arduino
app.get('/StatusSaidas', function(req,res){
    res.charset = 'UTF-8';
    console.log('Send to Arduino: ' + statusArdu);
    res.send(statusArdu);
Above, is the return from node.js with the response:
http://imgur.com/a/z74D5
I think the node.js sends the data, i see this in number "15" with the length of my status "QTD1LAMP, ON". but Arduino don't receive that info
By Luiz Henrique
#56724
martinayotte wrote:Try to print the "buffer" to figure out what is following the header.
If body is there after "\r\n\r\n", print "respota" to see if header removal code is good.
I print using this code:
Code: Select allSerial.print(resposta);
But receive nothing, no blank spaces, nothing.
Just another GET Request in Serial
Connection with HOST OK!
Part in this code:
Code: Select all  uint8_t buffer[1024] = {0};
    if (wifi.createTCP(HOST_NAME, HOST_PORT)) {
        Serial.print("connection with host OK\r\n");
    } else {
        Serial.print("Error connection Host\r\n");
    char *ComandoGET = "GET /StatusSaidas HTTP/1.1\r\nConnection: close\r\n\r\n";
    wifi.send((const uint8_t*)ComandoGET, strlen(ComandoGET));
    uint32_t len = wifi.recv(buffer, sizeof(buffer), 10000);
    char *resposta = buffer;
    for (int i = 0; i < len; i++)
        if (strncmp(resposta++, "\r\n\r\n", 4) == 0) break;
    resposta += 3;
