By Luiz Henrique
#56709 0
down vote
favorite
i don't response from GET request, send from ESP8266 + Arduino Mega to Node.js. My code in node receive the request, but i don't get nothing in Arduino Code.
Node.js
Code: Select allapp.get('/StatusSaidas', function(req,res){
    res.charset = 'UTF-8';
    console.log('Send to Arduino: ' + statusArdu);
    res.send(statusArdu);
Console log from Node.js
http://imgur.com/a/rKxYy
Code in Arduino
Code: Select alluint8_t buffer[1024] = {0};
  if (wifi.createTCP(HOST_NAME, HOST_PORT)) {
    Serial.print("Connection with Host OK!\r\n");
  } else {
    Serial.print("Error to connected to Host!\r\n");
  char *ComandoGET = "GET /StatusSaidas HTTP/1.1\r\nHost: SmartHouse\r\nConnection: close\r\n\r\n";
  wifi.send((const uint8_t*)ComandoGET, strlen(ComandoGET));
  uint32_t len = wifi.recv(buffer, sizeof(buffer), 10000);
  char *resposta = buffer;
  for (int i = 0; i < len; i++)
    if (strncmp(resposta++, "\r\n\r\n", 4) == 0) break;
  resposta += 3;
  receive = resposta;
  Serial.print(receive);
  Serial.print("\n\r");
Then the esp don't receive the answer, but the Node.js send strings like a: {QTD1LAMP, ON}
I don't know what is the problem with my code. Using ESP8266 with Arduino Mega
By popcorn
#56754 I think your node.js is not closing the http connection and 'thinks' your not ready with sending your data. I'm not sure
ARDUINO
: ' + statusArdu);
/// ADD THIS
    res.end();
/// ADD THIS ?
Did you try this code?
And did you try to get the page with your webbrowser from youre node.js program?
