I am working on a Web cam using the Adafruit HUZZAH ESP8266. I am using the TTL Serial JPEG Camera to take an image. The web page initially sends a response with an <img> tag that then triggers the handle_picture function. This should simply send a jpeg file to the browser.
The problem I am having appears to be with the server.streamFile function. In the snippet of code below it appears that the function does not read and send the entire file.
void handle_picture() {
byte clientBuf[64];
char filename[13];
strcpy(filename, "IMAGE01.JPG");
filename[5] = '0' + FileNum / 10;
filename[6] = '0' + FileNum % 10;
int32_t time = millis();
// strcpy(filename, "/test1.jpg"); // DEBUG only
f = SPIFFS.open(filename, "r");
if (!f) {
Serial.print("file open failed: ");
Serial.println(filename);
} else {
Serial.print("file opened: ");
int filesize = f.size();
Serial.print("File size ");
Serial.println(filesize); //For debugging only
String WebString = "";
WebString += "HTTP/1.1 200 OK\r\n";
WebString += "Content-Type: image/jpeg\r\n";
WebString += "Content-Length: " + String(filesize) + "\r\n";
WebString += "\r\n";
server.sendContent(WebString);
Serial.println (WebString);
ESP.wdtFeed();
count = 0;
size_t sent = server.streamFile(f,"image/jpeg");
Serial.print(sent);
Serial.println(" Bytes sent!");
f.close();
time = millis() - time;
Serial.print(time); Serial.println(" ms elapsed");
}// END handle_picture
As you can see, the output shows a file of 45012 bytes however, the streamFile only sends 4380 bytes!
Image size: 640x480
HTTP server started
Picture taken!
File number = 6
Filename: IMAGE06.JPG
Storing 45012 byte image.
File stored!
24623 ms elapsed
170853 mS Elasped for snapshot.
file opened: IMAGE06.JPG
File size 45012
HTTP/1.1 200 OK
Content-Length: 45012
4380 Bytes sent!
43 ms elapsed
I have looked thru many of the related posts however, I could not find a solution to similar posts / problems. I would appreciate any solutions / advice!
