By Matys
#61156 Hello There,
Im trying to get OTA working while there are interrupts implemented but im always getting WTD reset due to HW_timer
Here is my code:
https://github.com/v1ckdesigns/ESP_Dimm ... rature.ino
NoInterrupts(); and detachInterrupt() and hw_timer_set_func(0); does not seems to make any difference inside ArduinoOTA.onStart()
everything works fine if interrupts are commented out..
Regards
Matys
By Daemach
#61191 As odd as it sounds, after doing a serial upload make sure you reboot the board before attempting an OTA update. If the board is not physically rebooted, it will crash when OTA attempts to run.
By Matys
#61201 Yeah, im aware of that, im always doing power cycle after serial flash.
I found a workaround by adding a statement to turn off interrupts while both lights are off and handle OTA then, but still it makes me wonder why it does not work inside Arduino.onStart().
