By DTesla
#66510 Hi Pablo2048,
thank you for your reply. I will take a look. :) :)
I tried this: https://espressif.com/en/support/downlo ... d%5B%5D=14
but not working..everythings seems ok but sketch won't starts...
If I upload the sketch from Arduino IDE it works, if I export the bin file and flash it with the Flash download tool it won't works, even if I got no error from flasher...
What am I doing wrong? :)
Thanks
By Pablo2048
#66511 I'm using esptool from Arduino IDE (somewhere over tools/esptools directory - i'm on Linux :-) so You have to try searching for esptool.exe in Your Arduino directory...)
By QuickFix
#66517
Pablo2048 wrote:i'm on Linux :-) so You have to try searching for esptool.exe
By default, the (command-line version of) ESPTool on Windows is installed in the folder:
Code: Select allC:\Program Files (x86)\Arduino\hardware\esp8266com\Arduino\tools\esptool
