By rjo.rodrigues
#68382 Hardware: ESP-12E
Settings in IDE
Module: NodeMcu 1.0 (ESP-12E)
Flash Size: 4MB
CPU Frequency: 80Mhz
Upload Using: SERIAL
Sketch
extern "C" {
#include "user_interface.h"
#include "wpa2_enterprise.h"
#include <Arduino.h>
#include <ArduinoJson.h>
// SSID to connect to
static const char* ssid = "SSID";
// Username for authentification
static const char* username = "username";
// Password for authentification
static const char* password = "password";
const int ledPin = 0;
pinMode(ledPin, OUTPUT);
Serial.print("Tryingonnect to ");
Serial.println(ssid);
wifi_station_disconnect();
struct station_config wifi_config;
memset(&wifi_config, 0, sizeof(wifi_config));
strcpy((char*)wifi_config.ssid, ssid);
strcpy((char*)wifi_config.password, password);
wifi_station_set_config(&wifi_config);
wifi_station_set_wpa2_enterprise_auth(1);
wifi_station_set_enterprise_username((uint8*)username, strlen(username));
wifi_station_set_enterprise_password((uint8*)password, strlen(password));
wifi_station_connect();
Serial.print("Status: ");
Serial.println(wifi_station_get_connect_status());
// Wait for connection AND IP address from DHCP
delay(2000);
} // setup
