By antinym
#68669 The yield at the end of the main loop did not help any. I believe that yield is called at the end of the main loop.
I'm not sure that the "(effective) loop" you describe is anything other than normal behavior.
hmm..
By QuickFix
#68692 Another thing I thought about today: where are you handling any disconnects (after a prior connection)?
At some point wpastate becomes 3, but it never gets reset to 0 on a disconnect (or I must be missing something). :?
By antinym
#68697 I haven't gotten that far. I've adapted this code from another source online that puts everything in the setup(). But, I don't like waiting for for the Wifi to get setup before my MCU does stuff. If it were all in the setup() there'= would be no handling of disconnects either.
I could easily write something for wpastate=3 checking if WL_Connected something something something, but first thing is first, and that's just getting online consistently.
