By npashine
#76290 Hi earlephilhower and all,
I have used your library and its awesome, but it don't fulfill my requirement kindly help.
I have to play a dynamic generated samples from I2SNODAC, without any SPIFFS or SD card.
Also i need to record from I2SIN line and process the data into my SDK.
Last but not least i need to know how to make ESP8266 I2S TX and RX both as Slave and clock should be input.
By kokuam
#81373 Hello! Thank you for your great libraries!
I'm runnung slightly altered myPlayAACFromPROGMEM.ino example sketch with following results : https://youtu.be/ufrhHSXVtr4
Power source is more than powerfull, I've tried various, I tried different speakers (4 and 8Ohm) as well but hear loud crackle. Could you please take a look if it's possible to get a better quality? thank you!
#include <Arduino.h>
#include "AudioOutputI2SNoDAC.h"
#include "AudioGeneratorAAC.h"
#include "AudioOutputI2S.h"
#include "AudioFileSourcePROGMEM.h"
#include "sampleaac.h"
AudioFileSourcePROGMEM *in;
AudioGeneratorAAC *aac;
//AudioOutputI2S *out;
AudioOutputI2SNoDAC *out;
void setup(){
in = new AudioFileSourcePROGMEM(sampleaac, sizeof(sampleaac));
aac = new AudioGeneratorAAC();
//out = new AudioOutputI2S();
out = new AudioOutputI2SNoDAC();
aac->begin(in, out);
if (aac->isRunning()) {
aac->loop();
} else {
Serial.printf("AAC done\n");
delay(1000);
