By potzkin
#73255 hello all,i
need some help with mynodemcu OpenMQTTGateway.
actually i have 2 problems:
1-when i first starts my nodemcu it will only connect to broker if i open the serial monitor.
after that i can close serial monitor and it will run fine.
2-after it will connect it will fire the last command was on memory..
so every time it start up it will trigger my rf relay, if i will restart the broker it will send the last rf command also
im using rf to mqtt and mqtt to rf.
can anyone help me with this issue??
