By isan98
#84852 In this code, I want to know when the connection is disconnected for write LOW on the pin
digitalWrite(motor, LOW);
When the connection is disconnected, How can I do it?
#include <ESP8266WebServer.h>
#include <ArduinoJson.h>
#define motor  4                //D2
DynamicJsonBuffer jsonBuffer;
const char *ssid      = "ssid";
const char *password  = "password";
int sensorValue0 = 0;
String sensor_values;
ESP8266WebServer server(80);
void handleSentVar() {
  if (server.hasArg("sensor_reading"))
    sensor_values = server.arg("sensor_reading");
    Serial.print("**********************sensorValue:");
    Serial.println(sensor_values);
  JsonObject& root = jsonBuffer.parseObject(sensor_values);
      sensorValue0          = root["sensor0_reading"].as<int>();
  Serial.print("sensorValue0:");
  Serial.println(sensorValue0);
  toggle_motors();
  server.send(200, "text/html", "Data received");
  Serial.begin(9600);
  WiFi.softAP(ssid, password);
  pinMode(motor, OUTPUT);
  //toggle_motors();                 //turn off all leds as all the sensor values are zero
  server.on("/data/", HTTP_GET, handleSentVar); // when the server receives a request with /data/ in the string then run the handleSentVar function
  server.begin();
  server.handleClient();
  delay(1000);
void toggle_motors()
  if (sensorValue0 == 0){  digitalWrite(motor, LOW);
   Serial.println("++++++++++++++++off+++++++++++++");}
  if (sensorValue0 == 1){  digitalWrite(motor, HIGH);
  Serial.println("------------on-------------");}
