By CheapB
#13674
CheapB wrote:Thanks. I am using the esp8266_flasher.exe and I am getting this error on BOTH the good and the bad module when trying to flash :
Writing at 0x0007f800... (32 %)
Writing at 0x0007fc00... (32 %)
Writing at 0x00080000... (32 %)
Failed to write to target Flash
and now none of them will execute the bins from the Audrino IDE lol
Success! I flashed the module with an AT firmware - I used AI-v0.9.5.0 AT Firmware.bin and confirmed it accepted AT commands. Then I went back to the Arduino IDE and everything seems to be back to normal. Thanks for leading me in the right direction!
By CheapB
#13746
If you have problems connecting try to put the module in STA mode - either in your sketch or while you have the AT bin loaded. I had a problem where the ESP AP used the same channel as my router and prevented connection. Your Sketch will not set the mode unless you explicit set it.
