By pmsalvino
#93578 Hi! I wish you guys can help me out. I have a project in it NodeMCU is put in Slave position for SPI. In my project, I cannot insert libraries or scripts to the Master side, as NodeMCU should only get data from master.
I have already tried SPIslave.h libraries (Master & Slave) and using a protocol analiser, I’ve checked that Master in this case send a 0x02 followed by 0x00 byte before sending real data.
My problem: My real master send a sequence of 101(bit) followed by (000000) address and then data. It controls a HT1621B LCD driver.
So, SPI slave won’t receive 0x02 followed by 0x00 before true data.
Question: Is it possible to create “fake” bytes as soon as Enable line gets low to pretend first 2 bytes are 0x02 & 0x00?
I’ve been looking for this for a while and got stuck at this.
I appreciate any suggestions.
By pmsalvino
#93603 Since my last post, I’ve found some interesting approach to my issue in the blog below:
https://hydraraptor.blogspot.com/2018/0 ... mment-form
This guy manage to edit SPI register so Command could be 0 instead of 2 as default for the slave to write data.
If someone could give any other suggestion…
I believe the answer is somehow editing SPI register in Slave side. Unfortunately, I don’t know how to edit it.
