By miranthajayathilaka
#55940 I'm trying esp8266 post request to try and send two variable values through URL. The post request i have is shown below.
client.print(String("POST ") + url +
" HTTP/1.1\r\n" + "Host: " +
host + "\r\n" + "User-Agent: Arduino/1.0\r\n" + "Cache-Control: no-cache\r\n" +
"Content-Type: application/x-www-form-urlencoded" + "\r\n" + "Connection: close\r\n\r\n" +
"Content-Length: " + post.length() + "\r\n" + post );
The post data is like this.
String post = "number=1&status=OFF";
I'm using XAMPP to host the webpage. Everything seems to work fine but after execution what i receive is this on the php page.
Notice: Undefined index: number in C:\xampp\htdocs\pumpupdate.php on line 3
Notice: Undefined index: status in C:\xampp\htdocs\pumpupdate.php on line 4
which means the the $_GET commands in the php script don't reveive the variables sent to the page's URL. When i tried manually updating the url it worked fine, which i concluded as the php file working properly.
Please advice. really appreciate the help. Thanks.
By Ian Phill
#56762 Hello, I have been trying to connect two ESP Module for send a character "c" from Module A to Module B but I don't do nothing yet. I tried with OGMrStinky and Stoney code and nothing, the answer is connection failed...
In my project I just want to send one digit from Module A to Module B, if this is possible without TCP/IP or other thing complicated is better for me.
Thank you in advance.
I appreciate so much your help
server
#include <WiFiClient.h>
#include <ESP8266mDNS.h>
const char *ssid = "abc";
MDNSResponder mdns; //stoney
WiFiServer server(80);
WiFi.disconnect(); //stoney
delay(1000);
Serial.print("Configuring access point...");
WiFi.mode(WIFI_STA); //stoney
WiFi.softAP(ssid);
while (WiFi.status() != WL_CONNECTED) { delay(500); Serial.print("."); }
Serial.println("done");
Serial.print("AP IP address: ");
Serial.println(myIP);
server.begin();
mdns.update(); // Check for any mDNS queries and send responses
WiFiClient client = server.available(); // Check if a client has connected
if (!client) {
//return (NOCLIENT);
Serial.println("NOCLIENT");
Serial.println("");
Serial.println("New client");
// Wait for data from client to become available
while (client.connected() && !client.available()) {
delay(1);
// Read the first line of HTTP request
client
const char* ssid = "abc";
WiFiServer server(80); //stoney
IPAddress host(192,168,4,1);
delay(100);
Serial.println(ssid);
WiFi.begin(ssid);
Serial.print(".");
Serial.println("");
int position = 0;
WiFiClient client;
const char* host = "192.168.4.1";
const int httpPort = 80;
return;
String url = "/";
url += "?pos=";
url += String(position);
Serial.println(url);
"Host: " + host + "\r\n" +
"Connection: close\r\n\r\n");
delay(10);
while (client.available()) {
// String line = client.readStringUntil("</html>");
Serial.println(line);
int addr_start = line.indexOf("value=\"");
int addr_end = line.indexOf('\"', addr_start + 7);
if (addr_start == -1 || addr_end == -1) {
Serial.print("no data in line");
else {
String req = line.substring(addr_start + 7, addr_end);
Serial.print("start: ");
Serial.println(addr_start);
Serial.print("end: ");
Serial.println(addr_end);
Serial.print("Possy: ");
Serial.println(req);
By mrburnette
#56775
Ian Phill wrote:Hello, I have been trying to connect two ESP Module for send a character "c" from Module A to Module B but I don't do nothing yet.<...>
You are welcome to look over theTardis project: one ESP8266 sends ASCII and the other ESP8266(s) receive the transmission - one way because the sender uses UDP broadcasts.
Ray
By Toto Nano
#56933 help me, What changed if you want to make esp-01 as client?
I have learned and no found reference.
#include <Servo.h>
const char *ssid = "mywifi";
const char *pw = "qwerty123";
IPAddress ip(192, 168, 0, 1);
IPAddress netmask(255, 255, 255, 0);
const int port = 9876;
const int chCount = 4;
Servo servoCh[chCount];
int chPin[] = {0, 2, 14, 12};
int chVal[] = {1500, 1500, 1500, 1500};
int usMin = 700;
int usMax = 2300;
WiFiServer server(port);
WiFiClient client;
char cmd[100];
int cmdIndex;
unsigned long lastCmdTime = 60000;
unsigned long aliveSentTime = 0;
boolean cmdStartsWith(const char *st) {
  for(int i=0; ; i++) {
    if(st[i]==0) return true;
    if(cmd[i]==0) return false;
    if(cmd[i]!=st[i]) return false;;
  return false;
void exeCmd() {
  lastCmdTime = millis();
  if( cmdStartsWith("ch") ) {
    int ch = cmd[2] - '0';
    if(ch>=0 && ch<=9 && cmd[3]==' ') {
      chVal[ch] = (int)atof(cmd+4);
      if(!servoCh[ch].attached()) {
        servoCh[ch].attach(chPin[ch], usMin, usMax);
      servoCh[ch].writeMicroseconds(chVal[ch]);
  if( cmdStartsWith("ci") ) {
      chVal[ch] = -(int)atof(cmd+4);
  if( cmdStartsWith("ca") ) {
      chVal[ch] = (usMax+usMin)/2 + (int)( atof(cmd+4)*51 );
  if( cmdStartsWith("cb") ) {
      chVal[ch] = (usMax+usMin)/2 - (int)( atof(cmd+4)*51 );
  delay(1000);
  /*for(int i=0; i<chCount; i++) {
    servoCh[i].attach(chPin[i], usMin, usMax);
    chVal[i] = (usMin + usMax)/2;
    servoCh[i].writeMicroseconds( chVal[i] );
  cmdIndex = 0;
  WiFi.softAPConfig(ip, ip, netmask);
  WiFi.softAP(ssid, pw);
  server.begin();
  Serial.println("ESP8266 RC receiver 1.1 powered by RoboRemo");
  Serial.println((String)"SSID: " + ssid + "  PASS: " + pw);
  Serial.println((String)"RoboRemo app must connect to " + ip.toString() + ":" + port);
  if(millis() - lastCmdTime > 500) {
      servoCh[i].writeMicroseconds( (usMin + usMax)/2 );
      servoCh[i].detach();
  if(!client.connected()) {
    return;
  if(client.available()) {
    char c = (char)client.read();
    if(c=='\n') {
      cmd[cmdIndex] = 0;
      exeCmd();
      cmdIndex = 0;
    } else {
      cmd[cmdIndex] = c;
      if(cmdIndex<99) cmdIndex++;
  if(millis() - aliveSentTime > 500) {
    client.write("alive 1\n");
    aliveSentTime = millis();
