By PaulRB
#24048 certeza, your suggestion did not help, same result.
I added delay(1); into the empty while loop again. This enabled me to get an incorrect temp and an incorrect humid reading without the watchdog timer resetting. Here's my sketch:
Code: Select all/****************************************************************
 * ReadSHT2x
 *  An example sketch that reads the sensor and prints the
 *  relative humidity to the PC's serial port
 *  Tested with:
 *    - SHT21-Breakout Humidity sensor from Modern Device
 *    - SHT2x-Breakout Humidity sensor from MisensO Electronics
#include <Wire.h>
#include <SHT2x.h>
void setup()
  //delay(5000);
  Serial.println("Starting Wire...");
  Wire.begin(2, 0);
  Serial.println("Wire Started");
void loop()
  Serial.print("Humidity(%RH): ");
  Serial.print(SHT2x.GetHumidity());
  Serial.print("     Temperature(C): ");
  Serial.println(SHT2x.GetTemperature());
  delay(1000);
and here's the modified library code:
Code: Select all/*
  SHT2x - A Humidity Library for Arduino.
  Supported Sensor modules:
    SHT21-Breakout Module - http://www.moderndevice.com/products/sht21-humidity-sensor
   SHT2x-Breakout Module - http://www.misenso.com/products/001
  Created by Christopher Ladden at Modern Device on December 2009.
  Modified by Paul Badger March 2010
  Modified by www.misenso.com on October 2011:
   - code optimisation
   - compatibility with Arduino 1.0
  This library is free software; you can redistribute it and/or
  modify it under the terms of the GNU Lesser General Public
  License as published by the Free Software Foundation; either
  version 2.1 of the License, or (at your option) any later version.
  This library is distributed in the hope that it will be useful,
  but WITHOUT ANY WARRANTY; without even the implied warranty of
  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
  Lesser General Public License for more details.
  You should have received a copy of the GNU Lesser General Public
  License along with this library; if not, write to the Free Software
  Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301  USA
#include <inttypes.h>
#include <Wire.h>
#include "Arduino.h"
#include "SHT2x.h"
 * Global Functions
 * GetHumidity
 *  Gets the current humidity from the sensor.
 * @return float - The relative humidity in %RH
float SHT2xClass::GetHumidity(void)
   return (-6.0 + 125.0 / 65536.0 * (float)(readSensor(eRHumidityHoldCmd)));
 * GetTemperature
 *  Gets the current temperature from the sensor.
 * @return float - The temperature in Deg C
float SHT2xClass::GetTemperature(void)
   return (-46.85 + 175.72 / 65536.0 * (float)(readSensor(eTempHoldCmd)));
 * Private Functions
uint16_t SHT2xClass::readSensor(uint8_t command)
    uint16_t result;
    Wire.beginTransmission(eSHT2xAddress);   //begin
    Wire.write(command);               //send the pointer location
    delay(100);
    Wire.endTransmission();                  //end
    delay(100);
    Wire.requestFrom(eSHT2xAddress, 3);
    while(Wire.available() < 3) {
      delay(1);; //wait
    //Store the result
    result = ((Wire.read()) << 8);
    result += Wire.read();
   result &= ~0x0003;   // clear two low bits (status bits)
    return result;
SHT2xClass SHT2x;
Output now shows the following and then hangs:
Code: Select allStarting Wire...
Wire Started
Humidity(%RH): 118.99     Temperature(C): 128.86
By hansg
#24052 Here is my solution to get SDT21 running width ESP8266-12
I had the same issus as you .. WDT reset
Now i use the HTU21D lib from SparkFun.
I had to change the the Timing for temperature convert.
The sensirion datasheet : temperatur conversation takes max 85ms at 14bit resolution (default).
change the delay(55) line inside the readTemperature to delay(85)
this did the trick for me , now the Humidity and Temperature readings are OK
hope that helps ..
By certeza
#24148 This piece of code works reliably for me on an ESP-12 with SDA on pin 4 and SCL on pin 5.
Looking for SI7021 sensor...
I2C device found at address 0x40 !
Humidity: 58.50
Temperature: 27.30
done
Code: Select all#include <Wire.h>
#define I2C_ADDR 0x40
typedef enum {
    eTempPostHumidityCmd = 0xE0,
    eTempHoldCmd         = 0xE3,
    eRHumidityHoldCmd    = 0xE5,
    eTempNoHoldCmd       = 0xF3,
    eRHumidityNoHoldCmd  = 0xF5,
} HUM_MEASUREMENT_CMD_T;
uint16_t readSensor(byte command)
    uint16_t result;
    Wire.beginTransmission(0x40); //begin
    delay(100);
    Wire.requestFrom(0x40, 3);
    while( Wire.available() < 3 ) {
      delay(10); //wait
    //Store the result
    return result;
float GetHumidity(void)
 * GetTemperature
float GetTemperature(void)
bool reset(byte address)
  Wire.beginTransmission(address);
  Wire.write(0xFE);
  byte error = Wire.endTransmission();
  if (error == 0) {
    return true;
  return false;
void setup()
  Serial.println("\nStarting up...");
  Wire.begin(4,5);
  delay(100);
void loop()
  byte error;
  Serial.println("Looking for SI7021 sensor...");
  Wire.beginTransmission(I2C_ADDR);
  if (error == 0)
    Serial.print("I2C device found at address 0x");
    Serial.print(I2C_ADDR,HEX);
    Serial.println("  !");
//    if (reset(I2C_ADDR)) {
//       Serial.println("Device 0x40 reset.");;
       delay(85);
       Serial.print( "Humidity: " );
       Serial.println( GetHumidity() );
       delay(85);
       Serial.print( "Temperature: " );
       Serial.println( GetTemperature() );
  else if (error==4)
    Serial.print("Unknow error at address 0x");
    Serial.println(I2C_ADDR,HEX);
  Serial.println("done\n");
  delay(5000);   // wait 5 seconds for next request
By tytower
#24152 Get your power right first is what I suggest . Power hungry little buggers they be , they are drawing 250 mA plus in pulses every 100ms I'm told that's why the FTDI cables cant support them properly and that's also a likely cause of resets.
How are you finding the SHT21 ? The first site I visited sold them for $40 . Ebay has one to replace it and the DHT22 for about $7 now . I'm having an issue with the DHT22 that's why I ask.
