By schufti
#37861 obviously the sensor isn't found.
This could be due to
a) wrong pins used (NodeMCU has different notation)
GPIO0 --> D3 GPIO2 --> D4
b) bad i2c implementation
there were issues with AM2321 too, see here:
viewtopic.php?f=32&t=4483&p=26342#p26342
c) other problems e.g. i2c speed, try i2c-scanner
By Kaz260
#43915 You should use "No hold mode". I think it will work fine.
CODE:
typedef enum {
eTempNoHoldCmd = 0xF3,
eRHumidityNoHoldCmd = 0xF5,
} HUM_MEASUREMENT_CMD_T;
float SHT2xClass::GetTemperature(void){
float value = readSensor(eTempNoHoldCmd);
float SHT21xClass::GetHumidity(void) {
float value = readSensor(eRHeRHumidityNoHoldCmd);
