By GengusKahn
#36222 Hi there canedje, you have not displayed the actual code so it would not be possible to "guess" the reason. I have had similar problems and these are due to the CPU performing background tasks during "Delay" periods, the sketch below samples at 1 minute intervals you indicate 2 second intervals is this frequency a requirement?, if not sample at minimum of 4 second for a more stable result. If there is an option use DHT22 these are much more stable if the "erratic" readings are "single errors" then save the last sample and compare if value > expected newvalue = oldvalue should get rid of spikes.
The next problem is NAN, I have edited my library to produce "11.11" on error.....to avoid corruption of data types for charts when the sensor is "stressed", as one of these has been placed in an external position in a Scottish Winter........
http://82.5.78.180:92/graphic
Code: Select all/*---------------------------------------------------
                 _____
          _-_-_-_ *|* _-_-_-_
         -_-_-_-_-\@/-_-_-_-_-
HTTP 1.1 Temperature & Humidity Webserver for ESP8266
for ESP8266 adapted in the Arduino IDE
Espressif SDK Functionality in the form of a dignostics page
Server Layout
http://ipaddress/                        Web Text to LCD Input
                /diag                    SDK Functionality
                /monitor                 Google Gauges
                /graphic                 Google Line Chart
                /table                   Datalog Table
                /yfireset                Reset the WiFi Connection
                /srestart                Reboot the system(ESP must be cold booted, this will fail directly after uploading a sketch)
Credits to Stefan Thesen and The Guy's at .......http://www.ESP8266.com
With the use of http://espressif.com/new-sdk-release
The ESP8266 Arduino Reference http://arduino.esp8266.com/versions/1.6.5-1160-gef26c5f/doc/reference.html
With this release and a 1MByte Flash with 512KB SPIFFS can hold 3328 records of 120 bytes long Approx. 390KB
Set up an account at http://smtp2go.com
Encrypt your Password & Username using https://www.base64encode.org/
This evolution is the product of the Environment Monitor......
environmental.monitor.log@gmail.com
See a feed from 2 DHT11's on twitter at http://twitter.com/DDTMonitor
This will read various sensors and send an Email at a time or Sensor Condition
With the Data from the Sensors presented via Web Gauges, Graphs & Tables.....
Setup = 2 * DHT11 + DS18B20 and an ESP8266-07 with 1MB Flash
There are various pins used to load boot code so if you change pins and it does not boot this is WHY!!
I2C  GPios 4 & 5
DHT  GPio  14 & 16
To Index to a data point, each record is 64 bytes, there ar place holders to count in the string record
to select an individual data point.
The SPIFFS Record selction.......to allow reading/modifying a value.......
File dataFile1 = SPIFFS.open("/humidlog.CSV", "r"); //  a = append/modify, r = read or create w = write
  if(!dataFile1.seek(0, SeekSet))   //  Other Commands are seekCur or seekEnd
    Serial.println(F("Rewind fail"));
    dataFile1.close();
 stringholder = dataFile1.readStringUntil("[");  //Start of Record idexed to with file offset currently=0
__________________________________________________________________________________________________
......Use 5v to 3v Level Shifters as 5V devices like PIR and HC-SR04 can damage your device.......
 ___/'¬_         /\
{_-_ ^  \_______//
     \ _  _____  /
#include "FS.h"
#include "DHT.h"
#include <Wire.h>
#include <LiquidCrystal_I2C.h>
#include <OneWire.h>     // Used for temperature sensor(s)
#include <DallasTemperature.h>  // Specific for temperature sensors
OneWire oneWire(2);
DallasTemperature sensors(&oneWire);
LiquidCrystal_I2C lcd(0x3F,16,2);  // set the LCD address to YOUR LCD ADDRESS !!!
// WiFi connection
const char* ssid = "ssid";
const char* password = "password";
String toaddres = "RCPT To: <Valid Email>"; // Where your Last 24Hr Log has to be emailed To.......Time set below....
String frmaddrs = "MAIL From: <Vailid Email>";  // Where your Log has to be emailed From.......
String b64Usernm = "username encrypted";  // B64 Encrypted smtp2go Username
String b64Passwd = "Password encrypted";                              // B64 Encrypted smtp2go Password
String emailbutton = "off";
String lastdata;
String DsTable;             //Discarded parts if the Strings......
String tmtxt1;              //Strings from the Web....
String tmtxt2;
String stheDate;            //System Start Time...
String theDate;             // The current TimeStamp from Google....
boolean got_text = false;   //Print the Text to LCD if true......
unsigned long ulMeasCount=0;                         // values already measured
unsigned long ulMeasDelta_ms;                        // distance to next meas time
unsigned long ulNextMeas_ms;                         // next meas time
float pfTemp,pfHum,pfTemp1,pfHum1,pfVcC,pT;             // floats for Environment/System measurements stored in SPIFFS
unsigned long ulReqcount;                            // how often has a valid page been requested
unsigned long ulReconncount;                         // how often did we connect to WiFi
unsigned long Dfsize;                                // size of the datalog file
//NTP
char tDigit;
String TiMeS,TMnow,MyNtP;
int tIMeh,tIMem,tIMes,newt,newt1,inChar;
// Create an instance of the server on Port 80-89 = Sensor 1 - 10
WiFiServer server(80);
WiFiClient client;
char popyahoo[] = "smtpcorp.com";  // set email service
int port = 2525;
// DHT21 / AMS2301 / DHT11 /DHT22 //
#define DHTPIN 4
#define DHTPIN1 5
ADC_MODE(ADC_VCC);
// Uncomment whatever type you're using!
#define DHTTYPE DHT11   // DHT 11
//#define DHTTYPE DHT22   // DHT 22  (AM2302)
//#define DHTTYPE DHT21   // DHT 21 (AM2301)
// Declare each sensor
DHT dht(DHTPIN, DHTTYPE,16);
DHT dht1(DHTPIN1, DHTTYPE,16);
// needed to avoid link error on ram check
extern "C"
#include "user_interface.h"
void wsysreset()
  //Perform challenge to user before getting here to reboot !!!
  //Make an attempt to send mail or other backup of log files then reboot
    ESP.restart();
// the setup routine
void setup()
  Wire.begin(12,13);
  dht.begin();
  dht1.begin();
  sensors.begin();
  oneWire.reset_search();
  delay(50);
  sensors.requestTemperatures();
  pT=(sensors.getTempCByIndex(0));
  // setup globals
  ulReqcount=0;
  ulReconncount=0;
//    ulSecs2000_timer -= millis()/1000;  // keep distance to millis() counter
  pinMode(0, INPUT);  //Use the Flash Button.........to send email and reboot.......
  // initialize the lcd
  lcd.init();
  lcd.backlight();
  lcd.print("SensorInit Begin");
  delay(1000);
  // initialize the SPIFFS
  if (!SPIFFS.begin()) {
       lcd.print("SPIFFSinitFailed");
       while(1);
  // clear any old data....
     if (!SPIFFS.format()) {
      lcd.print("format failed");
      while(1);
  lcd.print("Sensor Init Done");
  delay(250);
  // inital connect
  WiFi.mode(WIFI_STA);
  delay(1000);
    // Connect to WiFi network
  lcd.clear();
  lcd.print("Connecting to ");
  lcd.setCursor(0, 1);
  lcd.print(ssid);
  delay(1000);
  WiFi.begin(ssid, password);
    lcd.print(".");
  server.begin();
  ulMeasDelta_ms = ( (unsigned long) 60 * 1000);  // Sample Interval 60 Seconds, this can be placed above in the declarations....
  ulNextMeas_ms = millis()+ulMeasDelta_ms;
  delay(2000);
    pfHum = dht.readHumidity();
    pfTemp = dht.readTemperature();
    pfHum1 = dht1.readHumidity();
    pfTemp1 = dht1.readTemperature();
 delay(2000);
  // connect to NTP and get time
  WiFiClient client;
  while (!!!client.connect("google.com", 80)) {
    lcd.clear();
    lcd.print("connection fail!");
  client.print("HEAD / HTTP/1.1\r\n\r\n");
  while(!!!client.available()) {
     yield();
  while(client.available()){
  client.readStringUntil('\n');
  String theDate1 = client.readStringUntil('\r'); //Date: Tue, 10 Nov 2015 19:55:38 GMT
    if (theDate1.startsWith("Date:")) {
      TiMeS=theDate1;
      theDate = theDate1.substring(11,17);
          client.flush();
          client.stop();
  inChar = TiMeS.charAt(30);
  newt=inChar-48;             // Convert Numerical Char to int.....
  inChar = TiMeS.charAt(29);
  newt1=inChar-48;
  tIMes=(newt1*10)+newt;
  inChar = TiMeS.charAt(27);
  newt=inChar-48;
  inChar = TiMeS.charAt(26);
  newt1=inChar-48;
  tIMem=(newt1*10)+newt;
  inChar = TiMeS.charAt(24);
  newt=inChar-48;
  inChar = TiMeS.charAt(23);
  newt1=inChar-48;
  tIMeh=(newt1*10)+newt;
  MyNtP=" ";
  MyNtP+=theDate;
  MyNtP+=" ";
  if (tIMeh<10){MyNtP+="0";}
  MyNtP+=tIMeh;
  MyNtP+=":";
  if (tIMem<10){MyNtP+="0";}
  MyNtP+=tIMem;
  MyNtP+=":";
  if (tIMes<10){MyNtP+="0";}
  MyNtP+=tIMes;
  MyNtP+=" GMT";
  String duration1 = " ";
int hr,mn,st;
   st = millis() / 1000;
   mn = st / 60;
   hr = st / 3600;
   st = st - mn * 60;
   mn = mn - hr * 60;
   if (hr<10) {duration1 += ("0");}
   duration1 += (hr);
   duration1 += (":");
   if (mn<10) {duration1 += ("0");}
   duration1 += (mn);
   duration1 += (":");
   if (st<10) {duration1 += ("0");}
   duration1 += (st);
int HRsa=hr+tIMeh;
int MNsa=mn+tIMem;
int SCsa=st+tIMes;
if (SCsa>59){SCsa-=60;MNsa+=1;}
if (MNsa>59){MNsa-=60;HRsa+=1;}
if (HRsa>23){HRsa-=24;}
    TMnow="";
    if (HRsa<10){TMnow += "0";}
    TMnow += HRsa;
    TMnow += ":";
    if (MNsa<10){TMnow += "0";}
    TMnow += MNsa;
    TMnow += ":";
    if (SCsa<10){TMnow += "0";}
    TMnow += SCsa;
delay(1000);
  lcd.clear();
  lcd.print("Environmental");
  lcd.print("Monitor   ");
  lcd.print(MyNtP);
// (re-)start WiFi
void WiFiStart()
  ulReconncount++;
  lcd.clear();
  lcd.print(ssid);
    lcd.print(".");
  lcd.clear();
  lcd.print("WiFi connected");
  // Start the server
  server.begin();
  lcd.print("Server started");
  lcd.clear();
  lcd.setCursor(0, 0);
  lcd.print("Network Started ");
  // Print the IP address
  lcd.print("IP= ");
  lcd.print(WiFi.localIP());
  lcd.clear();
  lcd.print("Environment | ");
  lcd.print(ulReconncount);
//  lcd.setCursor(0, 1);
//  lcd.print("Monitor");
  lcd.setCursor(0,1);
  lcd.print(theDate);
// make html table for measured data
unsigned long MakeTable (WiFiClient *pclient, bool bStream)
  unsigned long ulLength=0;
  // here we build a big table.
  // we cannot store this in a string as this will blow the memory
  // thus we count first to get the number of bytes and later on
  // we stream this out
  if (ulMeasCount==0)
    String sTable = "No data available yet.<BR>";
    if (bStream)
      pclient->print(sTable);
    ulLength+=sTable.length();
   File logF = SPIFFS.open("/humidlog.CSV", "r");
    if (!logF) {
      lcd.clear();
      lcd.print("rOr humidlog.CSV");
      while(1);
    String sTable;
    sTable = "<table style=\"width:100%\"><tr><th>Time / GMT</th><th>Int Temperature &deg;C</th><th>Int Humidity &#037;</th><th>Ext Temperature &deg;C</th><th>Ext Humidity &#037;</th><th>System Vcc</th><th>DS18B20 Temp &deg;C</th></tr>";
    sTable += "<style>table, th, td {border: 2px solid black; border-collapse: collapse;} th, td {padding: 5px;} th {text-align: left;}</style>";
//    for (unsigned long li=0;li<ulMeasCount;li++)
   DsTable = logF.readStringUntil('\'');
while(logF.available())
      sTable += "<tr><td>";
      sTable += logF.readStringUntil('\'');
     DsTable = logF.readStringUntil(',');
      sTable += "</td><td>";
      sTable += logF.readStringUntil(',');
      sTable += logF.readStringUntil(']');
      sTable += "</td></tr>";
      // play out in chunks of 1k
      if(sTable.length()>1024)
        if(bStream)
          //pclient->write(sTable.c_str(),sTable.length());
        sTable="";
    // remaining chunk
    sTable+="</table>";
    if(bStream)
  return(ulLength);
// make google chart object table for measured data
unsigned long MakeList (WiFiClient *pclient, bool bStream)
  // here we build a big list.
  if (ulMeasCount>0)
    if (!logF) {
      lcd.clear();
      while(1);
    String sTable="";
    while (logF.available())
    { // result shall be ['18:24:08 - 21.5.2015',21.10,49.00],
      sTable += "['";
      sTable += "',";
      sTable += "],\n";
        if(bStream)
        sTable="";
    // remaining chunk
    if(bStream)
  return(ulLength);
// create HTTP 1.1 header
String MakeHTTPHeader(unsigned long ulLength)
  String sHeader;
  sHeader  = F("HTTP/1.1 200 OK\r\nContent-Length: ");
  sHeader += ulLength;
  sHeader += F("\r\nContent-Type: text/html\r\nConnection: close\r\n\r\n");
  return(sHeader);
// make html footer
String MakeHTTPFooter()
  String sResponse;
  sResponse  = F(" ");
  sResponse += F("<BR>environmental.monitor.log@gmail.com<BR><FONT SIZE=-2>ESP8266 With DHT11 & DS18B20 Sensors<BR><FONT SIZE=-2>Compiled Using ver. 1.6.5-1160-gef26c5f, built on Sep 30, 2015</body></html>");
  return(sResponse);
// main loop
void loop()
  // Check button for email trigger
 int button = 0;           // variable for reading the pushbutton status
 button = digitalRead(0);  // read the state of the pushbutton on gpio 0
  if (button == LOW) {
  emailbutton = "Send";
  lcd.clear();
  lcd.print(F("Email Button...."));
  lcd.print(F("......Pressed.!!"));
  delay(1000);
  if (millis()==(ulNextMeas_ms-(ulMeasDelta_ms/2))){
  if (got_text == true){
   if (tmtxt1!=""){
        lcd.clear();
        lcd.print(tmtxt1);
        lcd.print(tmtxt2);
        delay(5000);
        else{  // Empty String returned CLEAR SCREEN
        got_text == false;
//  Use this instead of ESP.getVcc() for modules with LDR Fitted, Alter Display Text from Volts!!!
//  This is the Start of the LDR Sensor Measurement Percent/10 Saturation of LDR
//  Keep the Scale relavant for Line Graph or select Different Axis.....
delay(25);
int pfVcC = 10-(constrain(map((analogRead(A0)), 40, 900, 1, 10), 1, 10)) ;
delay(25);
//  This is the End of the LDR Sensor Measurement
  lcd.clear();
  lcd.print(pfTemp);
  lcd.setCursor(2, 0);
  lcd.print(F("C "));
  lcd.print(pfHum);
  lcd.setCursor(6, 0);
  lcd.print(F("% "));
  lcd.print(pfTemp1);
  lcd.setCursor(10, 0);
  lcd.print(F("C "));
  lcd.print(pfHum1);
  lcd.setCursor(14, 0);
  lcd.print(F("% "));
  lcd.print(P);
  lcd.print(F("mb"));
  lcd.setCursor(11, 1);
  lcd.print(TMnow);
  delay(1000);
  // Ping or PIR and check email button Halt/Reboot
  if (TMnow.startsWith("00:24") || emailbutton.startsWith("Sen")) {// Set the time for the Log to be emailed
    lcd.print(F("Got email - data"));
     if(sendEmail()) {
     lcd.clear();
     lcd.print(F("mail sent......"));
     wsysreset();
      else {
      lcd.clear();
      lcd.print(F("Email FAILED..!!!"));
      while(1);
  // do data logging
  if (millis()>=ulNextMeas_ms)
int hr,mn,st;
   mn = st / 60;
   hr = st / 3600;
   st = st - mn * 60;
   mn = mn - hr * 60;
   duration1 += (hr);
   duration1 += (":");
   duration1 += (mn);
   duration1 += (":");
   duration1 += (st);
int HRsa=hr+tIMeh;
int MNsa=mn+tIMem;
int SCsa=st+tIMes;
    TMnow="";
    TMnow += HRsa;
    TMnow += ":";
    TMnow += MNsa;
    TMnow += ":";
    TMnow += SCsa;
String  theDatet = theDate;
  delay(50);
  pfVcC =  ESP.getVcc();   // Only use this if Nothing connected to TOUT / ADC
  delay(150);
    delay(50);
delay(1000);
for (int lc=0;lc<3;lc++){
 if (pfTemp==11.11){
    delay(1000);
 if (pfTemp1==11.11){
    delay(2000);
    //pfTemp = pfTemp-=2;  // Calibrated with DHT22 !!!! Cheap Sensors.....
    //pfHum = pfHum-=10;   // Calibrated with DHT22 !!!!
    lastdata="";
    lastdata += pfTemp;
    lastdata += ",hum=";
    lastdata += pfHum;
    lastdata += ",temp1=";
    lastdata += pfTemp1;
    lastdata += ",hum1=";
    lastdata += pfHum1;
 String logdata = "['";
  logdata += theDate;
  logdata += " - ";
  logdata += TMnow;
  logdata += "'";
  logdata += ",";
  logdata += pfTemp;
if(pfTemp<10){logdata += '0';}
  logdata += ",";
  logdata += pfHum;
  logdata += ",";
  logdata += pfTemp1;
if(pfTemp1<10){logdata += '0';}
  logdata += ",";
  logdata += pfHum1;
  logdata += ",";
  logdata += pfVcC/1000;
  logdata += ",";
  logdata += pT;
  logdata += "]";
File logF = SPIFFS.open("/humidlog.CSV", "a");
  if (logF) {
    logF.print(logdata);
    logF.close();
    ulMeasCount++;
    else {
      lcd.clear();
      while(1);
  // check if WLAN is connected
  if (WiFi.status() != WL_CONNECTED)
    WiFiStart();
  if (!client)
    return;
  unsigned long ultimeout = millis()+250;
  while(!client.available() && (millis()<ultimeout) )
    delay(1);
  if(millis()>ultimeout)
    return;
  String sRequest = client.readStringUntil('\r');
  client.flush();
  // stop client, if request is empty
  if(sRequest=="")
    client.stop();
    return;
  // get path; end of path is either space or ?
  // Syntax is e.g. GET /?show=1234 HTTP/1.1
  String sPath="",sParam="", sCmd="";
  String sGetstart="GET ";
  int iStart,iEndSpace,iEndQuest;
  iStart = sRequest.indexOf(sGetstart);
  if (iStart>=0)
    iStart+=+sGetstart.length();
    iEndSpace = sRequest.indexOf(" ",iStart);
    iEndQuest = sRequest.indexOf("?",iStart);
    // are there parameters?
    if(iEndSpace>0)
      if(iEndQuest>0)
        // there are parameters
        sPath  = sRequest.substring(iStart,iEndQuest);
        sParam = sRequest.substring(iEndQuest,iEndSpace);
        // NO parameters
        sPath  = sRequest.substring(iStart,iEndSpace);
  // format the html response
  String sResponse,sResponse2,sHeader;
  //  Update LCD with text from Web
  //_________________________________________________________________
  // /ajax_inputs&L1=123456789&L2=abcdefghi&nocache=968337.7823963541
  //  1-9 on Line 1 and a - i on line 2
if (sPath.startsWith("/ajax_inputs&L1="))
     ulReqcount++;
     tmtxt1="";
     tmtxt2="";
    got_text = true;                    // print the received text to the LCD if found
File in = SPIFFS.open("/temp.txt", "w");
  if (in) {
    in.print(sPath);
    in.close();
    else {
      lcd.clear();
      lcd.print("rOr Temp.TXT");
      while(1);
     in = SPIFFS.open("/temp.txt", "r");
     in.setTimeout(0);
String Dtmtxt = in.readStringUntil('=');
       tmtxt1 += in.readStringUntil('&');
       tmtxt2 += in.readStringUntil('&');
     in.close();
       tmtxt1.replace("%20", " ");
       tmtxt2.replace("%20", " ");
        lcd.clear();
        lcd.print(tmtxt1);
        lcd.print(tmtxt2);
  // format the html page for gauges
 if(sPath=="/monitor")
    ulReqcount++;
    sResponse  = F("<html>\n<head>\n<title>Environment Monitor</title>\n<script type=\"text/javascript\" src=\"https://www.google.com/jsapi?autoload={'modules':[{'name':'visualization','version':'1','packages':['gauge']}]}\"></script>\n<script type=\"text/javascript\">\nvar temp=");
    sResponse += lastdata;
    sResponse += F(";\ngoogle.load('visualization', '1', {packages: ['gauge']});google.setOnLoadCallback(drawgaugetemp);google.setOnLoadCallback(drawgaugehum);google.setOnLoadCallback(drawgaugetemp1);google.setOnLoadCallback(drawgaugehum1);\nvar gaugetempOptions = {min: -10, max: 40, yellowFrom: -10, yellowTo: 16,redFrom: 28, redTo: 40, minorTicks: 10, majorTicks: ['-10','0','10','20','30','40']};\n");
    sResponse += F("var gaugehumOptions = {min: 0, max: 100, yellowFrom: 0, yellowTo: 25, redFrom: 70, redTo: 100, minorTicks: 10, majorTicks: ['0','10','20','30','40','50','60','70','80','90','100']};\nvar gaugehum1Options = {min: 0, max: 100, yellowFrom: 0, yellowTo: 25, redFrom: 70, redTo: 100, minorTicks: 10, majorTicks: ['0','10','20','30','40','50','60','70','80','90','100']};\n");
    sResponse += F("var gaugetemp1Options = {min: -10, max: 40, yellowFrom: -10, yellowTo: 16,redFrom: 28, redTo: 40, minorTicks: 10, majorTicks: ['-10','0','10','20','30','40']};\nvar gaugetemp,gaugehum,gaugetemp1,gaugehum1;\nfunction drawgaugetemp() {\ngaugetempData = new google.visualization.DataTable();\n");
    sResponse += F("gaugetempData.addColumn('number', 'Int \260C');\ngaugetempData.addRows(1);\ngaugetempData.setCell(0, 0, temp);\ngaugetemp = new google.visualization.Gauge(document.getElementById('gaugetemp_div'));\ngaugetemp.draw(gaugetempData, gaugetempOptions);\n}\n\n");
    sResponse += F("function drawgaugehum() {\ngaugehumData = new google.visualization.DataTable();\ngaugehumData.addColumn('number', 'Int %');\ngaugehumData.addRows(1);\ngaugehumData.setCell(0, 0, hum);\ngaugehum = new google.visualization.Gauge(document.getElementById('gaugehum_div'));\ngaugehum.draw(gaugehumData, gaugehumOptions);\n}\n");
    sResponse += F("\n\nfunction drawgaugetemp1() {\ngaugetemp1Data = new google.visualization.DataTable();\n");
    sResponse += F("gaugetemp1Data.addColumn('number', 'Ext \260C');\ngaugetemp1Data.addRows(1);\ngaugetemp1Data.setCell(0, 0, temp1);\ngaugetemp1 = new google.visualization.Gauge(document.getElementById('gaugetemp1_div'));\ngaugetemp1.draw(gaugetemp1Data, gaugetemp1Options);\n}\n\n");
    sResponse += F("function drawgaugehum1() {\ngaugehum1Data = new google.visualization.DataTable();\ngaugehum1Data.addColumn('number', 'Ext %');\ngaugehum1Data.addRows(1);\ngaugehum1Data.setCell(0, 0, hum1);\ngaugehum1 = new google.visualization.Gauge(document.getElementById('gaugehum1_div'));\ngaugehum1.draw(gaugehum1Data, gaugehum1Options);\n}\n");
    sResponse += F("</script>\n</head>\n<body>\n<font color=\"#000000\"><body bgcolor=\"#d0d0f0\"><meta name=\"viewport\" content=\"width=device-width, initial-scale=1.0, user-scalable=yes\"><h1>Environment Monitor</h1><BR><BR><FONT SIZE=+1>Last Sample Taken ");
    sResponse += TMnow;
    sResponse2 = F("GMT<BR>\n<div id=\"gaugetemp_div\" style=\"float:left; width:200px; height: 200px;\"></div> \n<div id=\"gaugehum_div\" style=\"float:left; width:200px; height: 200px;\"></div>\n<div style=\"clear:both;\"></div>\n<div id=\"gaugetemp1_div\" style=\"float:left; width:200px; height: 200px;\"></div> \n<div id=\"gaugehum1_div\" style=\"float:left; width:200px; height: 200px;\">");
    sResponse2 += F("</div>\n<div style=\"clear:both;\"></div><p><BR><a href=\"/graphic\">Sensor Graph Page</a><BR><a href=\"/table\">Sensor Datalog Page</a><BR><a href=\"/diag\">Diagnostics Information Page</a><BR><a href=\"/\">Monitor LCD Text Input Page</a></p>");
   sResponse2 += MakeHTTPFooter().c_str();
    // Send the response to the client
    client.print(MakeHTTPHeader(sResponse.length()+sResponse2.length()).c_str());
    client.print(sResponse);
    client.print(sResponse2);
  else if(sPath=="/")
    ulReqcount++;
    sResponse  = F("<html>\n<head>\n<title>Environment Monitor Text to LCD</title>\n<script>\n\n");
    sResponse += F("strLine1 = \"\";\nstrLine2 = \"\";\n\nfunction SendText()\n{\nnocache = \"&nocache=\" + Math.random() * 1000000;\nvar request = new XMLHttpRequest();\n\nstrLine1 = \"&L1=\" + document.getElementById(\"txt_form\").line1LCD.value;\nstrLine2 = \"&L2=\" + document.getElementById(\"txt_form\").line2LCD.value;\n\n");
    sResponse += F("request.open(\"GET\", \"ajax_inputs\" + strLine1 + strLine2 + nocache, true);\nrequest.send(null);\n}\n</script>\n<body>\n<h1>Environment Monitor<BR>LCD Text Input</h1>\n");
    sResponse += F("<BR><a href=\"/monitor\">Sensor Gauge Page</a><BR><a href=\"/graphic\">Sensor Graph Page</a><BR><a href=\"/table\">Sensor Datalog Page</a><BR><a href=\"/diag\">Diagnostics Information Page</a><BR>\n");
    sResponse += F("<body onload=\"GetESP8266IO()\">\n<h1><FONT SIZE=-1>Enter text to send to ESP8266 LCD:</h1>\n<form id=\"txt_form\" name=\"frmText\">\n<label>Line 1: <input type=\"text\" name=\"line1LCD\" size=\"16\" maxlength=\"16\" /></label><br /><br />\n<label>Line 2: <input type=\"text\" name=\"line2LCD\" size=\"16\" maxlength=\"16\" /></label>\n");
    sResponse += F("</form>\n<br />\n<input type=\"submit\" value=\"Send Text\" onclick=\"SendText()\" />\n\n");
    sResponse2 = F("<font color=\"#000000\"><body bgcolor=\"#d0d0f0\"><meta name=\"viewport\" content=\"width=device-width, initial-scale=1.0, user-scalable=yes\"><BR>LCD Text Input<BR>\n");
    sResponse2 += F("</div>\n<div style=\"clear:both;\"></div><p>");
else if(sPath=="/table")
  // format the html page for /tabelle
    ulReqcount++;
    unsigned long ulSizeList = MakeTable(&client,false); // get size of table first
    sResponse  = F("<html><head><title>Environment Monitor</title></head><body>");
    sResponse += F("<font color=\"#000000\"><body bgcolor=\"#d0d0f0\">");
    sResponse += F("<meta name=\"viewport\" content=\"width=device-width, initial-scale=1.0, user-scalable=yes\">");
    sResponse += F("<h1>Environment Monitor</h1>");
    sResponse += F("<FONT SIZE=+1><BR><a href=\"/monitor\">Sensor Gauges Page</a>");
    sResponse += F("<BR><a href=\"/graphic\">Sensor Graph Page</a><BR><a href=\"/diag\">Diagnostics Information Page</a><BR><a href=\"/\">Monitor LCD Text Input Page</a><BR><BR>Sample Interval 60 Seconds<BR>");
    // here the big table will follow later - but let us prepare the end first
    // part 2 of response - after the big table
    sResponse2 = MakeHTTPFooter().c_str();
    // Send the response to the client - delete strings after use to keep mem low
    client.print(MakeHTTPHeader(sResponse.length()+sResponse2.length()+ulSizeList).c_str());
    client.print(sResponse); sResponse="";
    MakeTable(&client,true);
  else if(sPath=="/graphic")
  // format the html page for /grafik
    ulReqcount++;
    unsigned long ulSizeList = MakeList(&client,false); // get size of list first
    sResponse  = F("<html>\n<head>\n<title>Environment Monitor</title>\n<script type=\"text/javascript\" src=\"https://www.google.com/jsapi?autoload={'modules':[{'name':'visualization','version':'1','packages':['corechart']}]}\"></script>\n");
    sResponse += F("<script type=\"text/javascript\"> google.setOnLoadCallback(drawChart);\nfunction drawChart() {var data = google.visualization.arrayToDataTable([\n['Time / GMT', 'InTmp', 'InHum', 'ExTmp', 'ExHum', 'SySVcc', 'DSTemp'],\n");
    // here the big list will follow later - but let us prepare the end first
    // part 2 of response - after the big list
    sResponse2  = F("]);\nvar options = {title: 'Environment',vAxes:{0:{viewWindowMode:'explicit',gridlines:{color:'black'},format:\"##.##\260C\"},1: {gridlines:{color:'transparent'},format:\"##,##%\"},},series:{0:{targetAxisIndex:0},1:{targetAxisIndex:1},2:{targetAxisIndex:0},3:{targetAxisIndex:1},4:{targetAxisIndex:0},5:{targetAxisIndex:0},},curveType:'function',legend:{ position: 'bottom'}};");
    sResponse2 += F("var chart = new google.visualization.LineChart(document.getElementById('curve_chart'));chart.draw(data, options);}\n</script>\n</head>\n");
    sResponse2 += F("<body>\n<font color=\"#000000\"><body bgcolor=\"#d0d0f0\"><meta name=\"viewport\" content=\"width=device-width, initial-scale=1.0, user-scalable=yes\"><h1>Environment Monitor</h1><BR><a href=\"/monitor\">Sensor Gauges Page</a><BR><a href=\"/table\">Sensor Datalog Page</a>");
    sResponse2 += F("<BR><a href=\"/diag\">Diagnostics Information Page</a><BR><a href=\"/\">Monitor LCD Text Input Page</a><BR><BR>\n<div id=\"curve_chart\" style=\"width: 600px; height: 400px\"></div>");
    MakeList(&client,true);
  else if(sPath=="/yfireset")
    ulReqcount++;
                                client.println("HTTP/1.1 200 OK");
                                client.println("Content-Type: text/html");
                                client.println("Connection: close");
                                client.println();
                                client.println("<!DOCTYPE HTML>");
                                client.print("<html><head><title>Environment Monitor</title></head><body>");
                                client.print("<font color=\"#000000\"><body bgcolor=\"#d0d0f0\">");
                                client.print("<meta name=\"viewport\" content=\"width=device-width, initial-scale=1.0, user-scalable=yes\">");
                                client.print("<h1>Environment Monitor<BR>WiFi Reset Page </h1>");
                                client.print("<BR><a href=\"/monitor\">Sensor Gauges Page</a><BR><a href=\"/graphic\">Sensor Graph Page</a><BR><a href=\"/table\">Sensor Datalog Page</a><BR><BR><BR><BR>Restarted WiFiConnections = ");
                                client.print(ulReconncount);
                                client.print("<BR><FONT SIZE=-2>environmental.monitor.log@gmail.com<BR><FONT SIZE=-2>ESP8266 With DHT11 & DS18B20 Sensors<BR>");
                                client.print("<FONT SIZE=-2>Compiled Using ver. 1.6.5-1160-gef26c5f, built on Sep 30, 2015<BR>");
                                client.println("<IMG SRC=\"https://raw.githubusercontent.com/genguskahn/ESP8266-For-DUMMIES/master/SoC/DimmerDocs/organicw.gif\" WIDTH=\"250\" HEIGHT=\"151\" BORDER=\"1\"></body></html>");
  WiFiStart();
  else if(sPath=="/diag")
     float   servolt1 = ESP.getVcc();
     long int spdcount = ESP.getCycleCount();
     delay(1);
     long int spdcount1 = ESP.getCycleCount();
     long int speedcnt = spdcount1-spdcount;
     FlashMode_t ideMode = ESP.getFlashChipMode();
     ulReqcount++;
     Dfsize = logF.size();
                                int hr,mn,st;
                                mn = st / 60;
                                hr = st / 3600;
                                st = st - mn * 60;
                                mn = mn - hr * 60;
                                duration1 += (hr);
                                duration1 += (":");
                                duration1 += (mn);
                                duration1 += (":");
                                duration1 += (st);
                                client.println();
                                client.print("<h1>Environment Monitor<BR>SDK Diagnostic Information</h1>");
                                client.print("<BR><a href=\"/monitor\">Sensor Gauges Page</a><BR><a href=\"/graphic\">Sensor Graph Page</a><BR><a href=\"/table\">Sensor Datalog Page</a><BR><a href=\"/\">Monitor LCD Text Input Page</a><BR>Restarted WiFiConnections = ");
                               String diagdat="";
                                diagdat+=ulReconncount;
                                diagdat+="<BR>  Web Page Requests = ";
                                diagdat+=ulReqcount;
                                diagdat+="<BR>  WiFi Station Hostname = ";
                                diagdat+=wifi_station_get_hostname();
                                diagdat+="<BR>  Free RAM = ";
                                client.print(diagdat);
                                client.print((uint32_t)system_get_free_heap_size()/1024);
                                diagdat=" KBytes<BR>  Logged Sample Count = ";
                                diagdat+=ulMeasCount;
                                diagdat+="<BR>  Total Sample points in 24 Hours = 1440<BR>  Minimum Sample Logging Interval = 1 Minutes<BR>  SDK Version = ";
                                diagdat+=ESP.getSdkVersion();
                                diagdat+="<BR>  Boot Version = ";
                                diagdat+=ESP.getBootVersion();
                                diagdat+="<BR>  Free Sketch Space  = ";
                                diagdat+=ESP.getFreeSketchSpace()/1024;
                                diagdat+=" KBytes<BR>  Sketch Size  = ";
                                diagdat+=ESP.getSketchSize()/1024;
                                diagdat+=" KBytes<BR>";
                                client.printf("  Flash Chip id = %08X\n", ESP.getFlashChipId());
                                client.print("<BR>");
                                client.printf("  Flash Chip Mode = %s\n", (ideMode == FM_QIO ? "QIO" : ideMode == FM_QOUT ? "QOUT" : ideMode == FM_DIO ? "DIO" : ideMode == FM_DOUT ? "DOUT" : "UNKNOWN"));
                                diagdat="<BR>  Flash Size By ID = ";
                                diagdat+=ESP.getFlashChipRealSize()/1024;
                                diagdat+=" KBytes<BR>  Flash Size (IDE) = ";
                                diagdat+=ESP.getFlashChipSize()/1024;
                                diagdat+=" KBytes<BR>  Flash Speed = ";
                                diagdat+=ESP.getFlashChipSpeed()/1000000;
                                diagdat+=" MHz<BR>  ESP8266 CPU Speed = ";
                                diagdat+=ESP.getCpuFreqMHz();
                                diagdat+=" MHz<BR>";
                                client.printf("  ESP8266 Chip id = %08X\n", ESP.getChipId());
                                diagdat="<BR>  System Instruction Cycles Per Second = ";
                                diagdat+=speedcnt*1000;
                                diagdat+="<BR>  Last System Restart Time = ";
                                diagdat+=MyNtP;
                                diagdat+="<BR>  Last System Restart Reason = ";
                                diagdat+=ESP.getResetInfo();
                                diagdat+="<BR>  System Time = ";
                                diagdat+=TMnow;
                                diagdat+=" (Last Recorded Sample Time)<BR>  System VCC = ";
                                diagdat+=servolt1/1000, 3;
                                diagdat+=" V <BR>  Datalog File Size in Bytes = ";
                                diagdat+=Dfsize;
                                diagdat+="<BR>  System Uptime =";
                                diagdat+=duration1;
                                client.print("<BR>  DS18B20 Temperature : ");
                                client.print(pT);
                                client.print("\260C<BR><FONT SIZE=-2>environmental.monitor.log@gmail.com<BR><FONT SIZE=-2>ESP8266 With DHT11 & DS18B20 Sensors<BR><FONT SIZE=-2>Compiled Using ver. 1.6.5-1160-gef26c5f, built on Sep 30, 2015<BR>");
                                diagdat="";
   else if(sPath=="/srestart")
                                client.println();
                                client.print("<h1>Environment Monitor<BR>Please wait 10 Seconds......<BR><FONT SIZE=+2>System Reset Page !!!! </h1>");
                                client.print("<BR><a href=\"/monitor\">Sensor Gauges Page</a><BR><a href=\"/graphic\">Sensor Graph Page</a><BR><a href=\"/table\">Sensor Datalog Page</a><BR><a href=\"/diag\">Diagnostics Information Page</a><BR><a href=\"/\">Monitor LCD Text Input Page</a><BR><BR><BR><BR>Restarted WiFiConnections = ");
                                client.print("<BR><BR><BR><FONT SIZE=-2>environmental.monitor.log@gmail.com<BR><FONT SIZE=-2>ESP8266 With DHT11 & DS18B20 Sensors<BR>");
client.stop();
wsysreset();
// 404 for non-matching path
    sResponse="<html><head><title>404 Not Found</title></head><body><h1>Not Found</h1><p>The requested URL was not found on this server, What did you sk for?.</p></body></html>";
    ulReqcount++;
    sHeader  = F("HTTP/1.1 404 Not found\r\nContent-Length: ");
    sHeader += sResponse.length();
    client.print(sHeader);
  // and stop the client
  client.stop();
byte sendEmail()
  byte thisByte = 0;
  byte respCode;
  if(client.connect( popyahoo,port) == 1) {
    lcd.clear();
    lcd.print(F("connectedsmtp2go"));
  } else {
    lcd.clear();
    lcd.print(F("SMconnect failed"));
    return 0;
  if(!eRcv()) {lcd.print("before ehlo");return 0 ;}
    lcd.clear();
    lcd.print(F("Sending ehlo"));
  client.print("EHLO ");
    client.println(WiFi.localIP());
  if(!eRcv()) {lcd.print("ehlo");return 0 ;}
  lcd.clear();
  lcd.print(F("Sending auth login"));
  client.println("auth login");
  if(!eRcv()) {lcd.print("auth");return 0 ;}
  lcd.print("Sending User");
// Change to your base64 encoded user
  client.println(b64Usernm);//
  if(!eRcv()) {lcd.print("user");return 0 ;}
  lcd.print(F("Sending Password"));
// change to your base64 encoded password
  client.println(b64Passwd);//
  if(!eRcv()) {lcd.print("ehlo");return 0;}
// change to your email address (sender)  Send All Mail to Environment Monitor
  client.println(frmaddrs);
  if(!eRcv()) {lcd.print("email");return 0 ;}
  lcd.clear();
// change to recipient address Send All Mail to Environment Monitor
  lcd.print(F("Sending To"));
  client.println(toaddres);
  lcd.clear();
  lcd.print(F("Sending DATA"));
  client.println("DATA");
  lcd.clear();
  lcd.print(F("Sending email"));
  client.println("To: The Environment Monitor <environmental.monitor.log@gmail.com>");
String sTable;
// change to your address This is sensor ID
  client.print("From: Weather Station 1 <");
  client.print(wifi_station_get_hostname());
  client.println(">");
  client.println("Subject: ESP8266 Daily Environment Report\r\n");
  client.println("This is Sent Directly from An ESP8266 Module every 24 Hours");
  client.print("The Total Number Of Environment Samples Values Being Tranferred Are -  ");
  client.println(ulMeasCount);
  client.println("_____________________________________________________________");
    if (!logF) {
      while(1);
  DsTable = logF.readStringUntil('[');
      sTable = logF.readStringUntil(']');
      client.println(sTable);
      sTable="";
  client.println("_________________End of Data_______________");
  client.println(".");
  if(!eRcv()) {lcd.print("aftersending");return 0 ;}
  lcd.print("Sending QUIT");
  client.println("QUIT");
  lcd.clear();
  if(!eRcv()) {lcd.print("afterQuit");return 0 ;}
  client.stop();
  lcd.print("disconnected");
  return 1;
byte eRcv()
  byte respCode;
  byte thisByte;
  int loopCount = 0;
  while(!client.available()) {
    delay(1);
    loopCount++;
    // if nothing received for 10 seconds, timeout
    if(loopCount > 10000) {
      client.stop();
      lcd.print("10 sec Timeout");
      return 0;
  respCode = client.peek();
    thisByte = client.read();
  if(respCode >= '4')
    efail();
    return 0;
  return 1;
void efail()
  byte thisByte = 0;
  int loopCount = 0;
    delay(1);
    loopCount++;
      client.stop();
      lcd.print("efail Timeout");
      return;
  client.stop();
By canedje
#36243
GengusKahn wrote:Hi there canedje, you have not displayed the actual code so it would not be possible to "guess" the reason. I have had similar problems and these are due to the CPU performing background tasks during "Delay" periods, the sketch below samples at 1 minute intervals you indicate 2 second intervals is this frequency a requirement?, if not sample at minimum of 4 second for a more stable result. If there is an option use DHT22 these are much more stable if the "erratic" readings are "single errors" then save the last sample and compare if value > expected newvalue = oldvalue should get rid of spikes.
                 _____
          _-_-_-_ *|* _-_-_-_
Server Layout
I2C  GPios 4 & 5
DHT  GPio  14 & 16
    dataFile1.close();
 ___/'¬_         /\
{_-_ ^  \_______//
     \ _  _____  /
#include "FS.h"
#include "DHT.h"
#include <Wire.h>
OneWire oneWire(2);
// WiFi connection
const char* ssid = ".......";
const char* password = ".......";
String lastdata;
String tmtxt2;
//NTP
char tDigit;
WiFiClient client;
int port = 2525;
#define DHTPIN 4
#define DHTPIN1 5
ADC_MODE(ADC_VCC);
extern "C"
void wsysreset()
    ESP.restart();
void setup()
  Wire.begin(12,13);
  dht.begin();
  dht1.begin();
  sensors.begin();
  delay(50);
  // setup globals
  ulReqcount=0;
  ulReconncount=0;
  lcd.init();
  lcd.backlight();
  delay(1000);
       while(1);
      while(1);
  delay(250);
  // inital connect
  delay(1000);
  lcd.clear();
  lcd.print(ssid);
  delay(1000);
    lcd.print(".");
  server.begin();
  delay(2000);
 delay(2000);
  WiFiClient client;
    lcd.clear();
     yield();
      TiMeS=theDate1;
          client.flush();
          client.stop();
  newt1=inChar-48;
  newt=inChar-48;
  newt1=inChar-48;
  newt=inChar-48;
  newt1=inChar-48;
  MyNtP=" ";
  MyNtP+=theDate;
  MyNtP+=" ";
  MyNtP+=tIMeh;
  MyNtP+=":";
  MyNtP+=tIMem;
  MyNtP+=":";
  MyNtP+=tIMes;
  MyNtP+=" GMT";
int hr,mn,st;
   mn = st / 60;
   hr = st / 3600;
   st = st - mn * 60;
   mn = mn - hr * 60;
   duration1 += (hr);
   duration1 += (":");
   duration1 += (mn);
   duration1 += (":");
   duration1 += (st);
int HRsa=hr+tIMeh;
int MNsa=mn+tIMem;
int SCsa=st+tIMes;
    TMnow="";
    TMnow += HRsa;
    TMnow += ":";
    TMnow += MNsa;
    TMnow += ":";
    TMnow += SCsa;
delay(1000);
  lcd.clear();
  lcd.print(MyNtP);
// (re-)start WiFi
void WiFiStart()
  ulReconncount++;
  lcd.clear();
  lcd.print(ssid);
    lcd.print(".");
  lcd.clear();
  // Start the server
  server.begin();
  lcd.clear();
  lcd.print("IP= ");
  lcd.clear();
  lcd.setCursor(0,1);
  lcd.print(theDate);
  if (ulMeasCount==0)
    if (bStream)
    if (!logF) {
      lcd.clear();
      while(1);
    String sTable;
        if(bStream)
        sTable="";
    // remaining chunk
    sTable+="</table>";
    if(bStream)
  return(ulLength);
  if (ulMeasCount>0)
    if (!logF) {
      lcd.clear();
      while(1);
    String sTable="";
      sTable += "['";
      sTable += "',";
      sTable += "],\n";
        if(bStream)
        sTable="";
    // remaining chunk
    if(bStream)
  return(ulLength);
  String sHeader;
  return(sHeader);
// make html footer
  String sResponse;
  sResponse  = F(" ");
  return(sResponse);
// main loop
void loop()
  lcd.clear();
  delay(1000);
   if (tmtxt1!=""){
        lcd.clear();
        lcd.print(tmtxt1);
        lcd.print(tmtxt2);
        delay(5000);
        got_text == false;
delay(25);
delay(25);
  lcd.clear();
  lcd.print(pfTemp);
  lcd.print(F("C "));
  lcd.print(pfHum);
  lcd.print(F("% "));
  lcd.print(pfTemp1);
  lcd.print(F("C "));
  lcd.print(pfHum1);
  lcd.print(F("% "));
  lcd.print(P);
  lcd.print(F("mb"));
  lcd.print(TMnow);
  delay(1000);
     if(sendEmail()) {
     lcd.clear();
     wsysreset();
      else {
      lcd.clear();
      while(1);
  // do data logging
int hr,mn,st;
   mn = st / 60;
   hr = st / 3600;
   st = st - mn * 60;
   mn = mn - hr * 60;
   duration1 += (hr);
   duration1 += (":");
   duration1 += (mn);
   duration1 += (":");
   duration1 += (st);
int HRsa=hr+tIMeh;
int MNsa=mn+tIMem;
int SCsa=st+tIMes;
    TMnow="";
    TMnow += HRsa;
    TMnow += ":";
    TMnow += MNsa;
    TMnow += ":";
    TMnow += SCsa;
  delay(50);
  delay(150);
    delay(50);
delay(1000);
 if (pfTemp==11.11){
    delay(1000);
    delay(2000);
    lastdata="";
    lastdata += pfTemp;
    lastdata += pfHum;
    lastdata += pfHum1;
  logdata += theDate;
  logdata += " - ";
  logdata += TMnow;
  logdata += "'";
  logdata += ",";
  logdata += pfTemp;
  logdata += ",";
  logdata += pfHum;
  logdata += ",";
  logdata += pfTemp1;
  logdata += ",";
  logdata += pfHum1;
  logdata += ",";
  logdata += ",";
  logdata += pT;
  logdata += "]";
  if (logF) {
    logF.close();
    ulMeasCount++;
    else {
      lcd.clear();
      while(1);
    WiFiStart();
  if (!client)
    return;
    delay(1);
    return;
  client.flush();
  if(sRequest=="")
    client.stop();
    return;
  if (iStart>=0)
    if(iEndSpace>0)
      if(iEndQuest>0)
        // NO parameters
     ulReqcount++;
     tmtxt1="";
     tmtxt2="";
  if (in) {
    in.print(sPath);
    in.close();
    else {
      lcd.clear();
      while(1);
     in.setTimeout(0);
     in.close();
        lcd.clear();
        lcd.print(tmtxt1);
        lcd.print(tmtxt2);
    ulReqcount++;
    sResponse += TMnow;
  else if(sPath=="/")
    ulReqcount++;
    ulReqcount++;
    ulReqcount++;
    ulReqcount++;
                                client.println();
  WiFiStart();
     delay(1);
     ulReqcount++;
                                int hr,mn,st;
                                mn = st / 60;
                                hr = st / 3600;
                                st = st - mn * 60;
                                mn = mn - hr * 60;
                                duration1 += (hr);
                                duration1 += (":");
                                duration1 += (mn);
                                duration1 += (":");
                                duration1 += (st);
                                client.println();
                               String diagdat="";
                                diagdat+=MyNtP;
                                diagdat+=TMnow;
                                diagdat+=Dfsize;
                                diagdat+=duration1;
                                client.print(pT);
                                diagdat="";
                                client.println();
client.stop();
wsysreset();
    ulReqcount++;
  client.stop();
byte sendEmail()
  byte thisByte = 0;
  byte respCode;
    lcd.clear();
  } else {
    lcd.clear();
    return 0;
    lcd.clear();
  lcd.clear();
  lcd.clear();
  lcd.clear();
  lcd.clear();
String sTable;
    if (!logF) {
      while(1);
      sTable="";
  lcd.clear();
  client.stop();
  return 1;
byte eRcv()
  byte respCode;
  byte thisByte;
  int loopCount = 0;
    delay(1);
    loopCount++;
      client.stop();
      return 0;
  if(respCode >= '4')
    efail();
    return 0;
  return 1;
void efail()
  byte thisByte = 0;
  int loopCount = 0;
    delay(1);
    loopCount++;
      client.stop();
      return;
  client.stop();
Thanks for the advice.
A good tip for a workaround. I implented it allready.
I do hate the need to use it. I want a stable reading.
So if somebody knows a stable solution, it will be apreciated.
I do use the DHT22 it is not stable in my opinion.
By canedje
#36245
GengusKahn wrote:The alternative is the HTU21d I2C, I have a few of these on the list to try......
offcourse. But I can not imagine that it is impossible to create stable readings with the DHT22. Allmost the whole world is using this sensor. I'm realy supprised
I'm not able to write a library myself, but I wish I could do that. I hope there is somebody out there willing to optimize the DHT22 library for the ESP
