Re: Going nutty trying to get a DHT11 to work
Posted: Mon Jul 27, 2015 5:09 am
tytower wrote:Angelo Santagata wrote:tytower, do you know what the correct speed for a DH11 is? 15 doesnt make much difference
I don't it is trial and error at this stage . There is a default rate set in the code I think . You will have to look it up . There is also a thread with a few posts on DHT22 and speeds . If I find it I'll post back. From memory I tried from 6 to about 40 and settled on 15 as did someone else in that thread.
Thanks, I'll try lots of values and report what works best for a DHT11.. However looking at the code it indicates that he 3rd value is no longer used (ignored) as the code "works" out the best timing...
I will investigate later this evening
