By eldonb46
#26827 martinayotte, and all,
OK, here is what I get, I have expanded the tests to include 3, 4, 5, and 6. The first two are your originals.
Test3 and Test4 uses a String Variables (which is the same length as your test)
Test5 and Test6 uses 30 short Strings in a loop, but the total transfer size is the same ( I think I have the size right ), also, they were modified to be consistent with functions I have previously tested, to show what I am seeing.
I have also added "FreeHeap" to the print, to make sure that was not a concern.
For my APPS, short html strings are typical used for Dynamic Web Pages ( although I do buffer them into a 1460 byte buffer before sending ).
If the functions "server.sendContent()" and "server.client().print()" share similar source code, I would think the time for Test5 and Test6 would be similar.
Note: My Web Page Server coding practices may be less than optimal, but I would not expect that much of a time difference, regardless of method used (assuming the coding is reasonable).
Thanks for your Assistance.
Eldon - WA0UWH
Code: Select allIP address: 192.168.2.162
MDNS responder started
HTTP server started
test1 duration = 71103, FreeHeap = 24408
test1 duration = 67384, FreeHeap = 24440
test1 duration = 22327, FreeHeap = 24440
test1 duration = 21619, FreeHeap = 24440
test2 duration = 7133, FreeHeap = 24504
test2 duration = 24740, FreeHeap = 24312
test2 duration = 16186, FreeHeap = 24120
test2 duration = 16348, FreeHeap = 23928
test3 duration = 60775, FreeHeap = 23672
test3 duration = 58506, FreeHeap = 23672
test3 duration = 306965, FreeHeap = 23544
test3 duration = 211195, FreeHeap = 23672
test4 duration = 20488, FreeHeap = 23736
test4 duration = 15849, FreeHeap = 21952
test4 duration = 16734, FreeHeap = 23352
test4 duration = 6687, FreeHeap = 23160
test5 duration = 63092283, FreeHeap = 24504
test5 duration = 63082917, FreeHeap = 24504
test5 duration = 63078014, FreeHeap = 24504
test5 duration = 63074285, FreeHeap = 24504
test6 duration = 99007, FreeHeap = 24312
test6 duration = 95931, FreeHeap = 24120
test6 duration = 63113, FreeHeap = 23928
test6 duration = 104843, FreeHeap = 23736
Here is the code that I am using in the HelloServer :
Code: Select all
  server.on("/",  handleRoot );
  server.on("/1", handleTest1);
  server.on("/2", handleTest2);
  server.on("/3", handleTest3);
  server.on("/4", handleTest4);
  server.on("/5", handleTest5);
  server.on("/6", handleTest6);
String gTestStringShort = "\
hello TEST1 from esp8266!\r\n\
// 30 small Copies, total length is the same as in original test
String gTestString = "\
// Original Test
void handleTest1() {
  int prevTime = micros();
  server.send(200, "text/plain", "hello TEST1 from esp8266!\r\nhello TEST1 from esp8266!\r\nhello TEST1 from esp8266!\r\nhello TEST1 from esp8266!\r\nhello TEST1 from esp8266!\r\nhello TEST1 from esp8266!\r\nhello TEST1 from esp8266!\r\nhello TEST1 from esp8266!\r\nhello TEST1 from esp8266!\r\nhello TEST1 from esp8266!\r\nhello TEST1 from esp8266!\r\nhello TEST1 from esp8266!\r\nhello TEST1 from esp8266!\r\nhello TEST1 from esp8266!\r\nhello TEST1 from esp8266!\r\nhello TEST1 from esp8266!\r\nhello TEST1 from esp8266!\r\nhello TEST1 from esp8266!\r\nhello TEST1 from esp8266!\r\nhello TEST1 from esp8266!\r\nhello TEST1 from esp8266!\r\nhello TEST1 from esp8266!\r\nhello TEST1 from esp8266!\r\nhello TEST1 from esp8266!\r\nhello TEST1 from esp8266!\r\nhello TEST1 from esp8266!\r\nhello TEST1 from esp8266!\r\nhello TEST1 from esp8266!\r\nhello TEST1 from esp8266!\r\nhello TEST1 from esp8266!\r\nhello TEST1 from esp8266!\r\nhello TEST1 from esp8266!\r\nhello TEST1 from esp8266!\r\nhello TEST1 from esp8266!\r\nhello TEST1 from esp8266!\r\nhello TEST1 from esp8266!\r\nhello TEST1 from esp8266!\r\nhello TEST1 from esp8266!\r\nhello TEST1 from esp8266!\r\nhello TEST1 from esp8266!\r\nhello TEST1 from esp8266!\r\nhello TEST1 from esp8266!\r\nhello TEST1 from esp8266!\r\nhello TEST1 from esp8266!\r\nhello TEST1 from esp8266!\r\nhello TEST1 from esp8266!\r\nhello TEST1 from esp8266!\r\nhello TEST1 from esp8266!\r\nhello TEST1 from esp8266!\r\nhello TEST1 from esp8266!\r\nhello TEST1 from esp8266!\r\n");
  int duration = micros() - prevTime;
  Serial.println(String("test1 duration = ") + duration + ", FreeHeap = " + ESP.getFreeHeap());
void handleTest2() {
  server.client().print( "HTTP/1.1 200 OK\r\nContent-Type: text/plain\r\n\r\n" );
  server.client().print("hello TEST2 from esp8266!\r\nhello TEST2 from esp8266!\r\nhello TEST2 from esp8266!\r\nhello TEST2 from esp8266!\r\nhello TEST2 from esp8266!\r\nhello TEST2 from esp8266!\r\nhello TEST2 from esp8266!\r\nhello TEST2 from esp8266!\r\nhello TEST2 from esp8266!\r\nhello TEST2 from esp8266!\r\nhello TEST2 from esp8266!\r\nhello TEST2 from esp8266!\r\nhello TEST2 from esp8266!\r\nhello TEST2 from esp8266!\r\nhello TEST2 from esp8266!\r\nhello TEST2 from esp8266!\r\nhello TEST2 from esp8266!\r\nhello TEST2 from esp8266!\r\nhello TEST2 from esp8266!\r\nhello TEST2 from esp8266!\r\nhello TEST2 from esp8266!\r\nhello TEST2 from esp8266!\r\nhello TEST2 from esp8266!\r\nhello TEST2 from esp8266!\r\nhello TEST2 from esp8266!\r\nhello TEST2 from esp8266!\r\nhello TEST2 from esp8266!\r\nhello TEST2 from esp8266!\r\nhello TEST2 from esp8266!\r\nhello TEST2 from esp8266!\r\nhello TEST2 from esp8266!\r\nhello TEST2 from esp8266!\r\nhello TEST2 from esp8266!\r\nhello TEST2 from esp8266!\r\nhello TEST2 from esp8266!\r\nhello TEST2 from esp8266!\r\nhello TEST2 from esp8266!\r\nhello TEST2 from esp8266!\r\nhello TEST2 from esp8266!\r\nhello TEST2 from esp8266!\r\nhello TEST2 from esp8266!\r\nhello TEST2 from esp8266!\r\nhello TEST2 from esp8266!\r\nhello TEST2 from esp8266!\r\nhello TEST2 from esp8266!\r\nhello TEST2 from esp8266!\r\nhello TEST2 from esp8266!\r\nhello TEST2 from esp8266!\r\nhello TEST2 from esp8266!\r\nhello TEST2 from esp8266!\r\nhello TEST2 from esp8266!\r\n");
  Serial.println(String("test2 duration = ") + duration + ", FreeHeap = " + ESP.getFreeHeap());
// Test using Strings
void handleTest3() {
  server.send(200, "text/plain", gTestString);
  Serial.println(String("test3 duration = ") + duration + ", FreeHeap = " + ESP.getFreeHeap());
void handleTest4() {
  server.client().print(gTestString);
  Serial.println(String("test4 duration = ") + duration + ", FreeHeap = " + ESP.getFreeHeap());
// Test using Short Strings
void handleTest5() {
  server.sendContent( "HTTP/1.1 200 OK\r\nContent-Type: text/plain\r\n\r\n" );
  for(int i = 0; i < 30; i++) {
    server.sendContent(gTestStringShort);
  Serial.println(String("test5 duration = ") + duration + ", FreeHeap = " + ESP.getFreeHeap());
void handleTest6() {
    server.client().print(gTestStringShort);
  Serial.println(String("test6 duration = ") + duration + ", FreeHeap = " + ESP.getFreeHeap());
By eldonb46
#26828 [quote="martinayotte"]Nope, still the same ...
Code: Select alltest1 duration = 4982
test2 duration = 3124
test1 duration = 3713
test2 duration = 3929
test1 duration = 4057
test2 duration = 3962
Interesting, your times for Test1 and Test2 are about 10 times faster than mine. I need to explore this.
Eldon - WA0UWH
