Re: Posting and getting data from ESP on Apache WebServer
Posted: Tue Dec 29, 2015 10:05 pm
This is exactly the help I was looking for in my project. I just can't seem to get the Sparkfun Thing to connect to the webserver. I added the LED light functionality in order to debug, but it never comes back on to say we're signing off. Which is why I'm thinking we're never connecting.
Here is my code.
I'm not throwing any errors, which is good but makes it more difficult to debug.
Here is my code.
#include <WiFiClient.h>
#include <WiFiServer.h>
// RaspPi Access Point w/ DHCP Login Cred
const char WiFiSSID[] = "TheAlamo";
const char WiFiPSK[] = "12345678";
const int LED_PIN = 5;
const int ANALOG_PIN = A0;
const char host[] = "192.168.4.1";
void setup()
pinMode(LED_PIN, OUTPUT);
pinMode(ANALOG_PIN, INPUT);
byte ledStatus = LOW;
WiFi.mode(WIFI_STA);
WiFi.begin(WiFiSSID, WiFiPSK);
// Blink the LED
digitalWrite(LED_PIN, ledStatus); // Write LED high/low
ledStatus = (ledStatus == HIGH) ? LOW : HIGH;
delay(100);
digitalWrite(LED_PIN, HIGH);
void loop()
//for testing purposes set temp to a default value.
//int temp = analogRead(ANALOG_PIN);
int temp = 43;
digitalWrite(LED_PIN, LOW);
WiFiClient client;
const int httpPort = 8000;
return;
//temp variable is set with a function to check the temp of an DS18B20 sensor. Let me know if you need it
String data = "temp1=" + (String)temp;
// "temp1=" is what is going to be sent using GET to the apache server, see code in add.php
// We now create a URI for the request
String url = "GET /add.php?" + data + " HTTP/1.1";
client.println(url);
client.println("Host: 192.168.4.1");
client.println("Connection: close");
client.println();
//End of Send.
while(client.available()){
Serial.print(line);
client.stop(); //Stopping client
ESP.deepSleep(60U*60*1000000); //U for unsigned
delay(1000); //for above sleep
