By chaeplin
#42438 Could you try this ? 11 hours tested(5 min deepsleep, report).
https://github.com/chaeplin/PietteTech_ ... psleep.ino
hiddenbit wrote:Hey chaeplin, my power source is a YwRobot powered over USB (SS), but also tested with 9V battery. The output is straight 3.3V. What do you mean with boost at the dht22? My dht22 is also powered via the YwRobot with 3.3V like the esp too.
By hiddenbit
#42487 Hey chaeplin, I still wasn't successful, but maybe the output helps ..
Code: Select allrll��|�l�| � l� b|����r�bl b��nn�lnn��� bp�lrlrlp�n� � l �� b n�|l����b��nn�l��l`�nn l`nr���n ��l`r��n ��l`��n�
2990
0
22.00
48.20
0
22.00
48.30
wifi on
. 0. 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23wifi conn done
reporting ---> :
22.00
48.30
 -----> goingToSleep
rll��|�l�| � l� b|����r�b� b��nn�lnn��� bp��lrlrlp�n� � l �� b n�|l����b��nn�l��l`�nn l`nr���n ��l`r��n ��l`��n�
3012
-7
 ets Jan  8 2013,rst cause:2, boot mode:(3,6)
load 0x4010f000, len 1264, room 16
tail 0
chksum 0x42
csum 0x42
~ld
3029
-7
tail 0
chksum 0x42
csum 0x42
~ld
3029
-7
tail 0
chksum 0x42
csum 0x42
~ld
3038
-7
tail 0
chksum 0x42
csum 0x42
~ld
3025
-7
tail 0
chksum 0x42
csum 0x42
~ld
3052
-7
tail 0
chksum 0x42
csum 0x42
~ld
3049
-7
tail 0
chksum 0x42
csum 0x42
~ld
3047
-7
tail 0
chksum 0x42
csum 0x42
~ld
By chaeplin
#42510 Check this viewtopic.php?f=29&t=8534
And ESP.reset changed to ESP.restart.
hiddenbit wrote:Hey chaeplin, I still wasn't successful, but maybe the output helps ..
2990
0
22.00
48.20
0
22.00
48.30
wifi on
reporting ---> :
22.00
48.30
 -----> goingToSleep
3012
-7
tail 0
chksum 0x42
csum 0x42
~ld
3029
-7
tail 0
chksum 0x42
csum 0x42
~ld
3029
-7
tail 0
chksum 0x42
csum 0x42
~ld
3038
-7
tail 0
chksum 0x42
csum 0x42
~ld
3025
-7
tail 0
chksum 0x42
csum 0x42
~ld
3052
-7
tail 0
chksum 0x42
csum 0x42
~ld
3049
-7
tail 0
chksum 0x42
csum 0x42
~ld
3047
-7
tail 0
chksum 0x42
csum 0x42
~ld
