Using a 9g mini servo, if I follow the wiring diagram from the original Arduino schematic, it does not work.
Do I need a logic level converter on the signal for this to work? (some posts say the 3.3V is suffice).
How are these wired?
Thanks,
Nic
Explore... Chat... Share...
schufti wrote:I only know a 9g mini SERVO. As "sweep" is a term not usually used with steppers and steppers usually won't be directly connected to the µC, I assume you talk about servos.
Since my crystal ball is at maintainance at the moment, I can't see neither your setup nor your sketch.
I can, otoh, confirm that in general all servos that I tried did run directly on the esp w/o any level shifting, just by using the "servo" lib accompanying the esp8266 core.
