https://github.com/esp8266/Arduino/issues/1426
where "igrr commented on 11 Feb":
Note that you should never disable interrupts for periods longer than 20 microseconds (that's what SDK release notes said).
I started to get some serious doubts. If the statement is correct and i do some simple math:
Suppose we use 9600 BAUD software serial
Using 9600 baud, 1 bit takes 104 uSec.
One byte equals to 10 bits, so one byte takes 1040 uSec
the transmit code has this:
cli();
send one byte of data, so takes 1040 uSecs...
sei();
so it disables interrupts for more than 1040 uSec. Far beyond the 20 uSec!
And the RX routine is an ISR routine that also waits for an entire byte to be received.
effectively blocking other interrupts.
So is it wise to include this into stable projects? The issue on github is still open, no milestone...
