- Sun Feb 26, 2017 7:32 am
#63044
Hi. I have switched from the ESP-01 to a NodeMCU v3 (D1 SCL, D2 SDA) and finally got the Raspberry to work as a logic level capture-device*.
This should be a fail:
http://i.imgur.com/XhHSBsy.pngAnd this should show a successful transmission:
http://i.imgur.com/awGkCHK.png I wanted to mention that (for some unknown reason) the communication started to randomly succeeded evey 10th or 20th time, and is currently working every 2nd time.
Current setup: Arduino Nano as master, Arduino Uno and NodeMCU as slaves and a Display. The NodeMCU is on the 3V3-side of a level-shifter. And to make sure that it's not the level-shifters fault, the signal from the Nano to the Uno (and the display) goes from the 5V-side of the level-shifter to the 3V3 side and then back again to the 5V side before it reaches the Uno.
The master (nano) requests a byte from each slave (esp, uno) and then writes the char to the first (esp) and second (uno) line of the Display.
The code on the slaves returns a character, that is incremented by 1 every time requestEvent(); is called.
chars sent by ESP
Code: Select alltry1: 1 345 7 9 ; = ?
try2: 1 3 5 7 9 ; = ?
try3: 1 3 5 7 9 ; = ?
try4: 1 3 5 7 9 ; = ?
try5: 1 3 5 7 9 ; = ?
the Uno works perfectly every time:
As you can see, the ESP doesn't just work 50% of the time, but (apart from the "glitch" in the first try) it works every 2nd time.
Tthe ESPs requestEvent() routine is called (the char is incremented) every time, but the communication from the ESP to the master isn't reliable yet.
Code running on the slaves:
Code: Select all#include <Wire.h>
uint8_t i='1';
delay(3000);
Serial.begin(9600); // start serial for output
Wire.begin(8); // join i2c bus (address optional for master)
Wire.onRequest(requestEvent); // register event
Serial.print("blobb");
delay(100);
void requestEvent() {
Wire.write(i);
i++;
if(i=='z'+1) {
i='1';
code running on the master:
#include <LiquidCrystal_I2C.h>
char c,d;
int i=0;
LiquidCrystal_I2C lcd(0x3F, 16,2); // Set the LCD I2C address
delay(2000);
lcd.begin(16,2); lcd.init(); lcd.backlight(); lcd.home (); //lcd.print("Hello, ARDUINO ");
Serial.begin(9600); Serial.println("hallo");
Wire.begin();
//Wire.setClock(31000L);
TWSR |= 3;
// while(!Serial.available()) {
// Serial.read();
while(i<16) {
c = ' ';
Wire.requestFrom(8, 1); // request 6 bytes from slave device
if(Wire.available()) { // slave may send less than requested
c = Wire.read(); // receive a byte as character
Serial.println(c); // print the character
delay(100);
d = ' ';
Wire.requestFrom(6, 1); // request 6 bytes from slave device
d = Wire.read(); // receive a byte as character
Serial.println(d); // print the character
delay(300);
lcd.setCursor(i,0);
lcd.print(c);
lcd.setCursor(i,1);
lcd.print(d);
delay(300);
i++;
/edit: I have included traces of the i2c transmission:
http://imgur.com/a/DXa8b The upper image (~8.5e5 should show a successful transmission, ~4.3e5 should be a fail)
*I had a look at a few different software solutions, but most were complicated and outdated. I now use
http://abyz.co.uk/rpi/pigpio/piscope.html
