Chat here about code rewrites, mods, etc... with respect to the github project https://github.com/esp8266/Arduino
By whats_up_skip
#66371 How do you change this code so that it will work with the ESP8266, rather than the CC3000?
I have done some research and attempts without any success. I wasn't able to obtain any assistance in the Arduino forum http://forum.arduino.cc/index.php?topic=214436.30 where it was discussed.
Any help would be appreciated.
Code: Select all/*
 Based on Andrew's sketch for capturing data from Ambient F007th Thermo-Hygrometer less the uploading it to Xively via Wifi and with the addition of a checksum check.
 Inspired by the many weather station hackers who have gone before,
 Only possible thanks to the invaluable help and support on the Arduino forums.
 With particular thanks to
 Rob Ward (whose Manchester Encoding reading by delay rather than interrupt
 is the basis of this code)
 https://github.com/robwlakes/ArduinoWeatherOS
 The work of 3zero8 capturing and analysing the F007th data
 http://forum.arduino.cc/index.php?topic=214436.0
 The work of Volgy capturing and analysing the F007th data
 https://github.com/volgy/gr-ambient
 Marco Schwartz for showing how to send sensor data to websites
 http://www.openhomeautomation.net/
 The forum contributions of;
 dc42: showing how to create 5 minute samples.
 jremington: suggesting how to construct error checking using averages (although not used this is where the idea of using newtemp and newhum for error checking originated)
 Krodal: for his 6 lines of code in the forum thread "Compare two sensor values"
 This example code is in the public domain.
 Additional work by Ron Lewis on reverse engineering the checksum
 What this code does:
 Captures Ambient F007th Thermo-Hygrometer data packets by;
 Identifying a header of at least 10 rising edges (manchester encoding binary 1s)
 Synchs the data correctly within byte boundaries
 Distinguishes between F007th data packets and other 434Mhz signals with equivalent header by checking value of sensor ID byte
 Correctly identifies positive and negative temperature values to 1 decimal place for up to 8 channels
 Correctly identifies humidity values for up to 8 channels
 Error checks data by rejecting;
 humidity value outside the range 1 to 100%
 bad checksums
 Hardware to use with this code
 6 F007th Thermo-Hygrometer set to different channels (can be adapted for between 1 and 8)
 A 434Mhz receiver
 17cm strand of CAT-5 cable as an antenna.
 CC3000 (I use the Adafruit breakout board with ceramic antenna)
 Code optimisation
 In order to improve reliability this code has been optimised to remove float values except when sending to Xively.
 This code does not provide any output to the serial monitor on what is happening,  see earlier versions for printouts.
 F007th Ambient Thermo-Hygrometer
 Sample Data:
 0        1        2        3        4        5        6        7
 FD       45       4F       04       4B       0B       52       0
 0   1    2   3    4   5    6   7    8   9    A   B    C   D    E
 11111101 01000101 01001111 00000100 01001011 00001011 01010010 0000
 hhhhhhhh SSSSSSSS NRRRRRRR bCCCTTTT TTTTTTTT HHHHHHHH CCCCCCCC ????
 Channel 1 F007th sensor displaying 21.1 Centigrade and 11% RH
 hhhhhhhh = header with final 01 before data packet starts (note using this sketch the header 01 is omitted when the binary is displayed)
 SSSSSSSS = sensor ID, F007th = Ox45
 NRRRRRRR = Rolling Code Byte? Resets each time the battery is changed
 b = battery indicator?
 CCC = Channel identifier, channels 1 to 8 can be selected on the F007th unit using dipswitches. Channel 1 => 000, Channel 2 => 001, Channel 3 => 010 etc.
 TTTT TTTTTTTT = 12 bit temperature data.
 To obtain F: convert binary to decimal, take away 400 and divide by 10 e.g. (using example above) 010001001011 => 1099
 (1099-400)/10= 69.9F
 To obtain C: convert binary to decimal, take away 720 and multiply by 0.0556 e.g.
 0.0556*(1099-720)= 21.1C
 HHHHHHHH = 8 bit humidity in binary. e.g. (using example above) 00001011 => 11
 CCCCCCCC = checksum? Note that this sketch only looks at the first 6 bytes and ignores the checksum
// Libraries
#include <SPI.h>
#define MAX_BYTES 7
#define countof(x) (sizeof(x)/sizeof(x[0]))
// Interface Definitions
int RxPin           = 8;   //The number of signal from the Rx
// Variables for Manchester Receiver Logic:
word    sDelay     = 242;  //Small Delay about 1/4 of bit duration
word    lDelay     = 484;  //Long Delay about 1/2 of bit duration, 1/4 + 1/2 = 3/4
byte    polarity   = 1;    //0 for lo->hi==1 or 1 for hi->lo==1 for Polarity, sets tempBit at start
byte    tempBit    = 1;    //Reflects the required transition polarity
boolean firstZero  = false;//flags when the first '0' is found.
boolean noErrors   = true; //flags if signal does not follow Manchester conventions
//variables for Header detection
byte    headerBits = 10;   //The number of ones expected to make a valid header
byte    headerHits = 0;    //Counts the number of "1"s to determine a header
//Variables for Byte storage
boolean sync0In=true;      //Expecting sync0 to be inside byte boundaries, set to false for sync0 outside bytes
byte    dataByte   = 0xFF; //Accumulates the bit information
byte    nosBits    = 6;    //Counts to 8 bits within a dataByte
byte    maxBytes   = MAX_BYTES;    //Set the bytes collected after each header. NB if set too high, any end noise will cause an error
byte    nosBytes   = 0;    //Counter stays within 0 -> maxBytes
//Variables for multiple packets
byte    bank       = 0;    //Points to the array of 0 to 3 banks of results from up to 4 last data downloads
byte    nosRepeats = 3;    //Number of times the header/data is fetched at least once or up to 4 times
//Banks for multiple packets if required (at least one will be needed)
byte  manchester[MAX_BYTES];   //Stores banks of manchester pattern decoded on the fly
// Variables to prepare recorded values for Ambient
byte stnId = 0;      //Identifies the channel number
int dataType = 0;    //Identifies the Ambient Thermo-Hygrometer code
int Newtemp = 0;
int Newhum = 0;
int ChanTemp[9];    //make one extra so we can index 1 relative
int ChanHum[9];
void setup()
    pinMode(RxPin, INPUT);
    eraseManchester();  //clear the array to different nos cause if all zeroes it might think that is a valid 3 packets ie all equal
// Main RF, to find header, then sync in with it and get a packet.
void loop()
    tempBit=polarity; //these begin the same for a packet
    noErrors=true;
    firstZero=false;
    headerHits=0;
    nosBits=6;
    nosBytes=0;
    while (noErrors && (nosBytes<maxBytes))
        while(digitalRead(RxPin)!=tempBit)
            //pause here until a transition is found
   }//at Data transition, half way through bit pattern, this should be where RxPin==tempBit
   delayMicroseconds(sDelay);//skip ahead to 3/4 of the bit pattern
   // 3/4 the way through, if RxPin has changed it is definitely an error
   if (digitalRead(RxPin)!=tempBit)
            noErrors=false;//something has gone wrong, polarity has changed too early, ie always an error
   }//exit and retry
       delayMicroseconds(lDelay);
       //now 1 quarter into the next bit pattern,
       if(digitalRead(RxPin)==tempBit) //if RxPin has not swapped, then bitWaveform is swapping
      //If the header is done, then it means data change is occuring ie 1->0, or 0->1
      //data transition detection must swap, so it loops for the opposite transitions
      tempBit = tempBit^1;
       }//end of detecting no transition at end of bit waveform, ie end of previous bit waveform same as start of next bitwaveform
       //Now process the tempBit state and make data definite 0 or 1's, allow possibility of Pos or Neg Polarity
       byte bitState = tempBit ^ polarity;//if polarity=1, invert the tempBit or if polarity=0, leave it alone.
       if(bitState==1) //1 data could be header or packet
      if(!firstZero)
          headerHits++;
          if (headerHits==headerBits)
         //Serial.print("H");
          add(bitState);//already seen first zero so add bit in
       }//end of dealing with ones
            {  //bitState==0 could first error, first zero or packet
           // if it is header there must be no "zeroes" or errors
           if(headerHits<headerBits)
               //Still in header checking phase, more header hits required
               noErrors=false;//landing here means header is corrupted, so it is probably an error
           }//end of detecting a "zero" inside a header
               //we have our header, chewed up any excess and here is a zero
               if (!firstZero) //if first zero, it has not been found previously
                        firstZero=true;
                        add(bitState);//Add first zero to bytes
                        //Serial.print("!");
                    }//end of finding first zero
                   add(bitState);
               }//end of adding a zero bit
                }//end of dealing with a first zero
            }//end of dealing with zero's (in header, first or later zeroes)
        }//end of first error check
    }//end of while noErrors=true and getting packet of bytes
} //end of mainloop
//Read the binary data from the bank and apply conversions where necessary to scale and format data
void add(byte bitData)
    dataByte=(dataByte<<1)|bitData;
    nosBits++;
    if (nosBits==8)
   nosBits=0;
   manchester[nosBytes]=dataByte;
   nosBytes++;
   //Serial.print("B");
    if(nosBytes==maxBytes)
   dataByte = 0xFF;
   // Subroutines to extract data from Manchester encoding and error checking
   // Identify channels 1 to 8 by looking at 3 bits in byte 3
   int stnId = ((manchester[3]&B01110000)/16)+1;
   // Identify sensor by looking for sensorID in byte 1 (F007th Ambient Thermo-Hygrometer = 0x45)
   dataType = manchester[1];
   // Gets raw temperature from bytes 3 and 4 (note this is neither C or F but a value from the sensor)
   Newtemp = (float((manchester[3]&B00000111)*256)+ manchester[4]);
   // Gets humidity data from byte 5
   Newhum =(manchester [5]);
        if ( Checksum (countof(manchester)-2, manchester+1) == manchester[MAX_BYTES-1])
            // Checks sensor is a F007th with a valid humidity reading equal or less than 100
            if ((dataType == 0x45) && (Newhum <= 100))
      ChanTemp[stnId] = Newtemp;
           ChanHum[stnId] = Newhum;
           // print raw data
           char Buff[128];
           for (int i=0; i<maxBytes; i++)
               sprintf(&Buff[i*3], "%02X ",manchester[i]);
      // 123456789 123456789 1234
                // Channel=1 F=123.1 H=12%<
      sprintf(&Buff[maxBytes*3],"  Channel=%d F=%d.%d H=%d%%\n",
                    stnId,
               (Newtemp-400)/10,
          Newtemp-(Newtemp/10)*10,
          Newhum);
                 Serial.print(Buff);
void eraseManchester()
    for( int j=0; j < 4; j++)
        manchester[j]=j;
uint8_t Checksum(int length, uint8_t *buff)
    uint8_t mask = 0x7C;
    uint8_t checksum = 0x64;
    uint8_t data;
    int byteCnt;
    for ( byteCnt=0; byteCnt < length; byteCnt++)
       int bitCnt;
   data = buff[byteCnt];
   for ( bitCnt= 7; bitCnt >= 0 ; bitCnt-- )
            uint8_t bit;
            // Rotate mask right
       bit = mask & 1;
       mask =  (mask >> 1 ) | (mask << 7);
       if ( bit )
      mask ^= 0x18;
       // XOR mask into checksum if data bit is 1
       if ( data & 0x80 )
          checksum ^= mask;
       data <<= 1;
    return checksum;
By btidey
#66378 The code here seems to be the code necessary to read the data from the Ambient sensor but not the code to transmit it onwards. The original used a CC3000 module interfaced by SPI to do this. THe full code for this seems to be at https://github.com/AMcAnerney/Arduino-F007th-Sketches
In the final code there you see that in the main loop after //end of while noErrors=true and getting packet of bytes, there is then a bunch of code to transmit the result via CC3000.
This solution was using an Arduino (with 433MHz receiver and the CC3000 widfi module.
I think you have 3 possible strategies here for using the ESP8266 instead of CC3000.
1. Interface from arduino to ESP8266 using SPI interface as had been used for the CC3000
2. Interface from arduino to ESP8266 using serial interface. I think the data rate required is not a problem.
3. Throw the arduino away and run all the code on the ESP8266. I.e connect the 433MHz receiver directly to the ESP8266 GPIO.
Method 1 sounds unnecessarily complicated to me. Method 2 is more straightforward and just needs RX/TX lines to be connected together. Personally I would do method 3. The code you posted for the 433MHz packet reception should run fine on an ESP8266. After the packet is received then you can just use the native wifi client functions to post the data on.
