I connected ESP8266 with Arduino Uno, and downloaded ESP8266 library(https://github.com/Diaoul/arduino-ESP8266)..
'joinAP' was OK and 'connect' was also OK.
But the problem was http request.
"getStatus(wifi.send("GET / HTTP/1.0\r\n\r\n"))" in setup code always showed me 'TIMEOUT'.
Below is my code.
Please save my code..
#include <SoftwareSerial.h>
#include "ESP8266.h"
#define SSID "SSID"
#define PASS "PASS"
#define DST_IP "www.google.com"
SoftwareSerial esp8266Serial = SoftwareSerial(2, 3);
ESP8266 wifi = ESP8266(esp8266Serial);
void setup()
Serial.begin(9600);
// ESP8266
esp8266Serial.begin(9600);
wifi.begin();
wifi.setTimeout(10);
/****** Basic commands ******/
// test
Serial.print("test: ");
Serial.println(getStatus(wifi.test()));
// restart
Serial.print("restart: ");
Serial.println(getStatus(wifi.restart()));
// getVersion
char version[16] = {};
Serial.print("getVersion: ");
Serial.print(getStatus(wifi.getVersion(version, 16)));
Serial.print(" : ");
Serial.println(version);
// getWifiMode
ESP8266WifiMode mode;
Serial.print("getWifiMode: ");
Serial.println(getStatus(wifi.getMode(&mode)));//*/
Serial.print("Wifi mode>>:");
Serial.println(mode);
if( mode != ESP8266_WIFI_STATION)
// setWifiMode
Serial.print("setWifiMode: ");
// Serial.println(getStatus(wifi.setMode(ESP8266_WIFI_ACCESSPOINT)));
Serial.println(getStatus(wifi.setMode(ESP8266_WIFI_STATION )));
Serial.println("already ESP8266_WIFI_STATION mode");
/****** WiFi commands ******/
// joinAP
Serial.print("joinAP: ");
Serial.println(getStatus(wifi.joinAP(SSID, PASS)));
/****** TCP/IP commands ******/
// connect
Serial.print("connect: ");
Serial.println(getStatus(wifi.connect(ESP8266_PROTOCOL_TCP, DST_IP, 80)));
// send
Serial.print("send: ");
Serial.println(getStatus(wifi.send("GET / HTTP/1.0\r\n\r\n")));
void loop()
// read data
unsigned int id;
int length;
int totalRead;
char buffer[300] = {};
if ((length = wifi.available()) > 0) {
id = wifi.getId();
totalRead = wifi.read(buffer, 300);
if (length > 0) {
Serial.print("Received ");
Serial.print(totalRead);
Serial.print("/");
Serial.print(length);
Serial.print(" bytes from client ");
//Serial.print("from client ");
Serial.print(id);
Serial.print(": ");
Serial.println((char*)buffer);
String getStatus(bool status)
if (status)
return "OK";
return "KO";
String getStatus(ESP8266CommandStatus status)
switch (status) {
case ESP8266_COMMAND_INVALID:
return "INVALID";
break;
case ESP8266_COMMAND_TIMEOUT:
return "TIMEOUT";
break;
case ESP8266_COMMAND_OK:
return "OK";
break;
case ESP8266_COMMAND_NO_CHANGE:
return "NO CHANGE";
break;
case ESP8266_COMMAND_ERROR:
return "ERROR";
break;
case ESP8266_COMMAND_NO_LINK:
return "NO LINK";
break;
case ESP8266_COMMAND_TOO_LONG:
return "TOO LONG";
break;
case ESP8266_COMMAND_FAIL:
return "FAIL";
break;
default:
return "UNKNOWN COMMAND STATUS";
break;
String getRole(ESP8266Role role)
switch (role) {
case ESP8266_ROLE_CLIENT:
return "CLIENT";
break;
case ESP8266_ROLE_SERVER:
return "SERVER";
break;
default:
return "UNKNOWN ROLE";
break;
String getProtocol(ESP8266Protocol protocol)
switch (protocol) {
case ESP8266_PROTOCOL_TCP:
return "TCP";
break;
case ESP8266_PROTOCOL_UDP:
return "UDP";
break;
default:
return "UNKNOWN PROTOCOL";
break;
