Re: IR sender library
Posted:
Sun Jul 05, 2015 4:03 pm
by martinayotte
ofer221 wrote:it works grate but I can't restart the module without pulling out the IR transmitter first
@AntonKa, if you are facing the same issue as ofer211, I've answered earlier ont his thread that connecting a LED or a IRLED to ground is acting as pull-down on GPIO2, so it prevent booting properly. The polarity need to be reversed and connected to VCC, of course in the software doing a digitalWrite(LED, LOW) will turn on the LED, so polarity need to be reversed there too.
Posted:
Mon Aug 10, 2015 12:52 am
by dmpotter
Awesome, got my working right away with a ESP8266 12E.
I cobbled some code from another thread ->
viewtopic.php?f=29&t=3787Code: Select all#include <ESP8266WiFi.h>
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#include <ESP8266mDNS.h>
#include <IRremoteESP8266.h>
const char* ssid = "......................................";
const char* password = ".............................";
IRsend irsend(13); //an IR led is connected to GPIO pin 13
MDNSResponder mdns;
ESP8266WebServer server(80);
void handleRoot() {
server.send(200, "text/plain", "hello from esp8266!");
void handleNotFound(){
String message = "File Not Found\n\n";
message += "URI: ";
message += server.uri();
message += "\nMethod: ";
message += (server.method() == HTTP_GET)?"GET":"POST";
message += "\nArguments: ";
message += server.args();
message += "\n";
for (uint8_t i=0; i<server.args(); i++){
message += " " + server.argName(i) + ": " + server.arg(i) + "\n";
server.send(404, "text/plain", message);
void setup(void){
pinMode(13,OUTPUT);
Serial.begin(9600);
WiFi.begin(ssid, password);
Serial.println("");
// Wait for connection
Serial.println("");
Serial.println(ssid);
Serial.print("IP address: ");
if (mdns.begin("esp8266", WiFi.localIP())) {
Serial.println("MDNS responder started");
server.on("/", handleRoot);
server.on("/IRSignal", [](){
server.send(200, "text/plain", "Sent Signal");
irsend.sendNEC(0xFF40BF,36);
Serial.println("Signal Sent, doing delay");
delay(3000);
Serial.println("Delay Over");
server.onNotFound(handleNotFound);
server.begin();
void loop(void){
server.handleClient();
So, to just access the webserver which in my run showed up as 192.168.1.16
Connected to PRETTYFLYFORAWIFI
IP address: 192.168.1.16
HTTP server started
Delay Over
Then I was able to just add the extension
http://192.168.1.16/IRSignalThe important part was adding pinMode without that I guess it didn't know it was an output.
Just to make sure it worked without all the webserver stuff this is the basic code.
Code: Select all/*
* IRremoteESP8266: IRsendDemo - demonstrates sending IR codes with IRsend
* An IR LED must be connected to ESP8266 pin 0.
* Version 0.1 June, 2015
* Based on Ken Shirriff's IrsendDemo Version 0.1 July, 2009, Copyright 2009 Ken Shirriff, http://arcfn.com
IRsend irsend(13); //an IR led is connected to GPIO pin 0
void setup()
irsend.begin();
Serial.begin(9600);
Serial.println("NEC");
irsend.sendNEC(0xFF40BF, 36);
delay(10000);
What I really want to be able to do is use the maker channel on IFTTT and send power on, power off signals. I have been able to send to IFTTT just haven't worked out a running monitor for the trigger part. Separate topic though I'm sure. But hypothetically, "if (THIS LIGHT GETS TURNED ON) then (USE IR via 8322 to turn this ON)".
Posted:
Fri Jan 15, 2016 1:40 pm
by aegiacometti
Hi there...
I have a code wich is working on ArduinoUno, but does not work with ESP.
My remote is not recognized so I need to use sendRaw, i get that raw code/timmings with Arduino.
unsigned int IR_AA_ON[] = {4300,4400, 500,1650, 500,600, 500,1650, 500,1650, 550,550, 500,550, 550,1600, 550,550, 550,550, 500,1650, 500,600, 500,600, 500,1650, 500,1650, 500,550, 550,1650, 500,600, 500,600, 500,550, 500,1700, 500,1600, 550,1600, 550,1650, 500,1650, 500,1700, 450,1650, 550,1600, 550,600, 500,550, 500,600, 500,550, 500,600, 500,1650, 550,550, 500,1650, 500,1700, 500,1600, 500,600, 550,550, 500,550, 550,600, 500,1600, 550,550, 500,600, 500,550, 550,1650, 500,1650, 500,1650, 500};
int khz = 38; // 38kHz carrier frequency
for (int i = 0; i < 3; i++) {
irsend.sendRaw(IR_AA_ON, sizeof(IR_AA_ON) / sizeof(IR_AA_ON[0]), khz);
delay(5);
I can see the IRled blinking, but something must be different because does not work with ESP.
Any advice?
thks
Posted:
Tue Mar 07, 2017 3:49 am
by gggggggg
aegiacometti wrote:Hi there...
Hi @aegiacometti did you get this working?
