When will a finished Library be available to implement in to projects?
I can see adding MQTT to this would be really cool.
Idea to control TV or smart box via IR via MQTT.
Keep up the good work mate
Dans
When I try to run simple sever for sending IR codes, it works grate but I can't restart the module without pulling out the IR transmitter first , otherwise the esp blue led stays on and no connection is made.
Some one had something like this ?
I have esp 8266 - 01
boot version - 1.2
AT version - 0.21.0.0
SDK version - 0.9.5
connections :
VCC - 3.3v ( power sorce )
GND - gnd ( power sorce )
CH-PD - pullup 10k- 3.3v ( power sorce )
GPIO 2 / 0 - IR led - gnd (tried both gpio2 and gpio 0 )
also tried to pull up GPIO 0 with 10 k to 3.3v
and here is the code :
#include <IRremoteESP8266.h>
#include <IRremoteInt.h>
#include <string.h>
#include <stdlib.h>
IRsend irsend(2);
const char* ssid = "...........";
const char* password = "..............";
WiFiServer server(80);
delay(10);
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
server.begin();
irsend.begin();
if (!client) {
return;
Serial.println("new client");
while(!client.available()){
delay(1);
String req = client.readStringUntil('H');
Serial.println(req);
client.flush();
String req2 = req.substring(5,14);
unsigned long number = req2.toInt();
delay(1);
Serial.println(req2);
Serial.println(number);
irsend.sendNEC(number, 32);
client.flush();
delay (100);
So, the solution is to reverse the LEDs and have them connected to VCC, and in the firmware, simply reverse polarity too : 0 means LED On and 1 means LED Off.
