I have a similar problem. I did test with IRLed. If you connect Led ( no IRLed ), it will be work. I did not find solution except to connect IRLed with Led together.
May be it will help you.
When I try to run simple sever for sending IR codes, it works grate but I can't restart the module without pulling out the IR transmitter first , otherwise the esp blue led stays on and no connection is made.
Some one had something like this ?
I have a similar problem. I did test with IRled. If you connect Led ( no IRLed ), it will be work. I did not find solution except to connect IRLed with Led together.
