This is the basic system information:
- Fedora: 22
- Eclipse: 4.4.2
- Arduino IDE: 1.6.5
As I mentioned before, the Arduino IDE has been previously configured to compile and upload sketches to the ESP with no issues at all.
I install the latest (2.2.0.1) "Arduino Eclipse Extensions" plug-in from "http://www.baeyens.it/eclipse/V2", and restart Eclipse. In "Window > Preferences" I fill all the paths for my IDE, private library, and hardware. Then I create a "New Arduino Sketch", fill in all the information, and copy one of my working sketches inside the ".cpp" file already created inside the project.
Now, when I try to build the project, it fails with the message "/bin/sh: /bin/xtensa-lx106-elf-g++: No such file or directory", because the compiler is not at "/bin". After some investigation, I add the following lines to my "/home/eperez/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/platform.txt" file:
runtime.platform.path=/home/eperez/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0
runtime.tools.xtensa-lx106-elf-gcc.path={runtime.platform.path}/../../../tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9
runtime.tools.esptool.path={runtime.platform.path}/../../../tools/esptool/0.4.5
I delete the project, create a new one, copy the code, and build the project. Now I get a "fatal error: ESP8266WiFi.h: No such file or directory"... Ops! I forgot to add the libraries; I go to "Add library to the selected project" and add "esp8266", "ESP8266WiFi", and "ESP8266WebServer". Clean the project, build again, and get:
Starting combiner
"/home/eperez/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/../../../tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/xtensa-lx106-elf-gcc" -g -Os -nostdlib -Wl,--no-check-sections -u call_user_start -Wl,-static "-L/home/eperez/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/tools/sdk//lib" "-L/home/eperez/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/tools/sdk//ld" "-Teagle.flash.512k.ld" -Wl,-wrap,system_restart_local -Wl,-wrap,register_chipv6_phy -o "/home/eperez/workspace/IOT/Release/IOT.elf" -Wl,--start-group ./IOT.cpp.o ./Libraries/ESP8266WiFi/src/ESP8266WiFi.cpp.o ./Libraries/ESP8266WiFi/src/ESP8266WiFiMulti.cpp.o ./Libraries/ESP8266WiFi/src/WiFiClient.cpp.o ./Libraries/ESP8266WiFi/src/WiFiServer.cpp.o ./Libraries/ESP8266WiFi/src/WiFiUdp.cpp.o ./Libraries/ESP8266WebServer/src/ESP8266WebServer.cpp.o ./Libraries/ESP8266WebServer/src/Parsing.cpp.o /home/eperez/workspace/IOT/Release/arduino.ar "/home/eperez/workspace/IOT/Release/arduino.ar" -lm -lgcc -lhal -lphy -lnet80211 -llwip -lwpa -lmain -lpp -lsmartconfig -lwps -lcrypto -Wl,--end-group "-L/home/eperez/workspace/IOT/Release"
/home/eperez/workspace/IOT/Release/arduino.ar(core_esp8266_main.cpp.o):(.text+0x14): undefined reference to `cont_run'
makefile:76: recipe for target 'IOT.elf' failed
/home/eperez/workspace/IOT/Release/arduino.ar(core_esp8266_main.cpp.o): In function `loop_task':
/home/eperez/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266/core_esp8266_main.cpp:117: undefined reference to `cont_run'
/home/eperez/workspace/IOT/Release/arduino.ar(core_esp8266_main.cpp.o): In function `abort':
/home/eperez/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266/core_esp8266_main.cpp:70: undefined reference to `cont_yield'
/home/eperez/workspace/IOT/Release/arduino.ar(core_esp8266_main.cpp.o): In function `esp_yield':
/home/eperez/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266/core_esp8266_main.cpp:76: undefined reference to `cont_yield'
make: *** [IOT.elf] Error 1
These "cont_something" routines seem to be defined at "/home/eperez./packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/cores/esp8266/cont.S"; but I do not know how to add them to the Eclipse plug-in... any hints here, please?
https://github.com/jantje/arduino-eclip ... issues/293
Also ... it may be useful, at the end of this post you will find a link to a PDF where I keep my ESP8266 notes. On page 162, are my recipes for getting Eclipse working with the Arduino environment. However, I was using Windows and not Linux....
