Chat here about code rewrites, mods, etc... with respect to the github project https://github.com/esp8266/Arduino
By dannybackx
#33787 Hi, I am building an app so an ESP8266-12 with e.g. a motion sensor can be queried using the UPnP protocols. See https://github.com/dannybackx/arduino-upnp .
This is my first development in this environment so I am probably doing some things wrong.
Question #1 is how I can debug something like this. Can I use information such as the crash dump below to figure out what's going on ? On other mobile platforms, I have been able to debug remote apps via gdb. Is this possible here as well ?
Question #2 is if I'm doing something obvious wrong in my code. The app sometimes runs for a while (if I comment out pieces of it), the version currently on github crashes very quickly.
Thanks for any input,
Danny
Boot version 31
Flash chip Real size 4194304, size 4194304
SDK version 1.2.0
Starting WiFi... MAC 5C:CF:7F:06:72:4C, SSID {xxxxxxxxxxxxx}, IP address 192.168.1.44
Mode: STA
PHY mode: N
Channel: 1
AP id: 0
Status: 5
Auto connect: 1
SSID (13): xxxxxxxxxxxxx
Passphrase (10): xxxxxxxxxx
BSSID set: 0
Starting HTTP...
Starting SSDP...
SSDP UUID: 38323636-4558-4dda-9188-cda0e606724c
UPnP begin(3ffea5a0, 3ffea238)
UPnPService ctor
UPnPService.addAction(GetState,_,<action><name>getState</name><argumentList><argument><retval/><name>State</name><relatedStateVariable>State</relatedStateVariable><direction>out</direction></argument></argumentList></action>)
UPnPService.addStateVariable(State,string,1)
Ready!
Sending Notify to 239.255.255.250:1900
Sending Response to 192.168.1.63:65288
Exception (28):
epc1=0x40101802 epc2=0x00000000 epc3=0x00000000 excvaddr=0x027f67e4 depc=0x00000000
ctx: sys
sp: 3ffff630 end: 3fffffb0 offset: 01a0
>>>stack>>>
3ffff7d0: 00000024 00000001 40211cdf 3ffffebc
3ffff7e0: 3fff68fc 3fff5e70 3ffffebc 3ffeb50c
3ffff7f0: 00000000 40211b4f 3fff5e70 3ffffebc
3ffff800: 3fff68fc 3fff5e74 3ffff86f 40209424
3ffff810: 7f5e0001 2db4faff 4020bc10 00010b06
3ffff820: 3fff68fc 3ffffebc 3ffeb50c 40206fdd
3ffff830: 3ffff86b 3fff5e74 00000011 00000000
3ffff840: 000000ff 00000014 3ffff86a 4020bb86
By kolban
#33797 The exception code includes "epc1" which is the program counter value in effect when the exception occurred. You can use this with a map of your linked program to determine the exact assembler instruction being executed. At a minimum, you can find the names of the function you were in when the exception occurred.
By dannybackx
#33881 /home/danny/src/sketchbook/esp8266/libraries/GDBStub/src/GDBStub.c:29:29: fatal error: xtensa/corebits.h: No such file or directory
Did I overlook some instruction, something appears to be missing from my environment.
Danny
