I've been working on integrating the HTTPUpdateServer into my esp arduino based project, and I've hit a snag. I get the following error during compilation:
no matching function for call to 'ESP8266HTTPUpdateServer::setup(WiFiServer*)'
The difference between my code and the example sketch is that I am using "WiFiServer" library to create a web server and handle http requests and it looks like the ESP8266WebServer library, which is used in the example, is different.
My question is, does anyone have a recommendation on the best path forward on this? Should I try to convert my code from using WiFi to use WebServer or should I do something else. I wasn't able to look into the libraries themselves yet, but could anyone comment on the actual differences?
Thanks for any thoughts!
