ESP8266 Webserver Project
Moderator: Sprite_tm
By tve
#17491 Thanks for the encouragement! Attached is another patch with a shell script to reflash the esp using curl. It's also added to the Makefile as 'make wiflash' assuming you have set the ESP_HOSTNAME in the makefile (or environment). The shell script takes care of uploading the correct partition and this set-up works quite well for me. I'll probably add a web page to manually upload the firmware, but this may take a few days. I don't really want to do it as long as I can't distinguish between user1.bin and user2.bin in the handler 'cause such as mix-up would be very uncool.
If you want to get started, you will need the SDK 1.0.1 (1.0.0 should also work), flash the boot_v1.3(b3).bin from the SDK's bin directory to 0x00000, flash blank.bin to 0x7E000, flash firmware/user1.bin to 0x01000, then connect to the AP and configure /wifi to hook up to your local AP. After that 'make wiflash' should reflash your puppy...
By wwpants
#17577 Yes this will be incredibly useful please keep it in the public repo :)
On another note - did you ever figure out the issue with slow WiFi? I know you had mentioned in another forum that you were not getting packets fast?
Thanks
Jay
By tve
#17716 At this point I don't expect to do more work on the flashing in the short term. What I have works for me for now. I type 'make wiflash' and it comples, uploads, restarts all in one. I added checks to ensure that a proper firmware gets uploaded but not a user1.bin vs user2.bin check. I looked into it and it's not trivial. The best would be to add a marker into each binary explicitly and check for that.
The next thing would be to download the firmware from a (cloud) server. Similar to what espressif supports but I'd like to be able to download from a github release or something like that. I'm not planning on adding a form-upload page 'cause I don't have a use for it and I find it too error prone (the user1.bin vs. user2.bin thing). Either you're developing your firmware and then 'make wiflash' is the most convenient or you want to consume a ready-made firmware and then might as well download it straight from github.
It would be great for Jeroen to chime in whether he wants to merge in what I did or not. I'm happy to make changes to make it mergable. My stuff is now at https://github.com/jeelabs/esp-link/tree/ota-mods (note ota-mods branch, you can diff with the 'upstream' branch to see everything I changed, the master branch has further changes for my own project).
By Sashpi
#18324 Great work tve. This is exactly what I've been looking for although my journey on the OTA part has only just started.
I need to further dive into the work you already did.
Did anybody already manage to do the OTA upgrade for files of >512KB size? The flash locations change at that point and I'm not quite sure how this impacts the process and how the bootloader knows where to load user2.bin from.
