ESP8266 Webserver Project
Moderator: Sprite_tm
By jwoodman
#15444 I've got a strange problem where the ESP-HTTPD example seems to run just fine on my ESP-07 boards, but on my ESP-12 boards I get the following error:
Code: Select allReady
mode : null
Fatal exception (28):
epc1=0x40240550, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00000000, depc=0x00000000
I've made no modifications to the project yet, just compiled and flashed using esp-open-sdk.
Any idea why the two modules would behave differently with this project?
By jwoodman
#15496 Alright I did manage to get the ESP-HTTPD example working with the ESP-12 modules. Instead of using "make flash" and "make htmlflash" I used nodemcu-flasher (with the binaries set properly in the Config tab) and changed the flash size to 4MByte under the Advanced tab.
By Sprite_tm
#21576 Hmm, it may have something to do with the 4MB of flash; the standard esphttpd example compiles for a 512KB flash making the flash bit where the SDK expects the WiFi parameters to be end up wrong. Does a 'make blankflash' do anything for you?
