Moderator: Sprite_tm
Problem: Smartphone or any other client device can not connect to esp8266 in AP+STA mode.
As soon as the module is lightly touched near the antenna it works.
Once connected the finger can be removed and the connection is still stable.
Note: The signal strength is quite weak when trying to connect, as soon as the
finger is "used" it greatly improves and stays strong once connected even after finger removal.
Wiring:
GPIO0 -- 5kOhm -- VCC (ams1117)
CH_PD -- 5kOhm -- VCC (ams1117)
VCC -- VCC (ams1117)
GND -- GND (ams1117)
GND -- GND (cp2102)
TX -- RX (cp2102)
RX -- TX (cp2102)
Between VCC and GND is a 220uF 35v Capacitor
Reset is not connected as it is pulled high by an internal resistor, also the device does not reset at any time, so this seems no problem.
This hardware setup works for other esp-01 modules I have without a problem.
Exact version:
commit fc784cc6b5e98979016509a462d0bc6674b42a4f
Date: Sat Jul 4 13:41:57 2015 -0700
Steps:
git clone https://github.com/pfalcon/esp-open-sdk
cd esp-open-sdk
make STANDALONE=y
wget http://bbs.espressif.com/download/file.php?id=564
mv file.php\?id\=564 esp_iot_sdk_v1.2.zip
unzip esp_iot_sdk_v1.2.zip
cd ..
git clone https://github.com/jeelabs/esp-link
cd esp-link
git submodule init
git submodule update
Now edit Makefile to set sdk path and serial interface
export PATH=/home/user/esp8266/esp-open-sdk/xtensa-lx106-elf/bin:$PATH
dd if=/dev/zero bs=1k count=512 | tr '\000' '\377' > blank512k.bin
../esp-open-sdk/esptool/esptool.py --port /dev/ttyUSB1 --baud 460800 write_flash 0x00000 blank512k.bin
make flash
Now the real dilemma, I have another esp-01 module that works with the exact same steps and hardware setup. I even did this:
Connect "good" esp-01 module
../esp-open-sdk/esptool/esptool.py --port /dev/ttyUSB1 --baud 460800 read_flash 0x00000 524288 esp8266_working.bin
Now connect the "bad" esp-01 module
../esp-open-sdk/esptool/esptool.py --port /dev/ttyUSB1 --baud 460800 write_flash 0x00000 esp8266_working.bin
But it still did not work!
At this point everybody will say the module is just damaged, right?
This is the evil twist:
git clone https://github.com/israellot/esp-ginx
cd esp-ginx
make flash
And it works - no problem at all!
HELP!
That "magic wire" actually works as good as the finger
Try soldering the capacitor directly onto the pins of the module. Also keep in mind that it is not only the antenna that makes wireless communication possible. You also need a proper ground plane as "counterbalance" for the dipole.
