ESP8266 Webserver Project
Moderator: Sprite_tm
By Guimoz
#25265 Hi,
I am quite new to the ESP8266 world but I have been learning a lot recently.
My purpose is to be able to control a led strip with a webpage provided by the ESP. The led strip is controlled with Mosfets and a PCA9685 board (a simple PWM module). This board communicates via I2C. The only working library I have found for the PCA is using the Wire library included in the Arduino IDE. If I use the IDE I can successfully send orders to the PCA.
However I want to use ESP-HTTPD so I can't use the Arduino IDE.
I wanted to know how I could use the Wire library in the ESP-HTTPD .
Do you have any suggestion ?
If you think that I should do my project differently tell me.
Thanks for your help
PS : I have found an I2C library : https://github.com/eadf/esp8266_i2c_master but if I use it I would have to rewrite my own PCA9685 library and I am no C expert at all
If you want to read the PCA9685 datasheet it is here
