Sming - Open Source framework for high efficiency native ESP8266 development
By Pedraum
#54389 good personal afternoon, I wonder if someone already implemented tcp with USART
send via tcp and receive the serial is working as the code below:
bool servidorSocketProtocoloRecebido(TcpClient& cliente, char *protocolo, int tamanho)
Serial.print(protocolo);
return true;
receive the serial also is working only can not I send via tcp what could be.
void recebeSerial(Stream& stream, char arrivedChar, unsigned short availableCharsCount)
tcpServer.writeString("test"); //does not work
Serial.print ("test"); sends to the serial
I noticed that in tcpip there is the client as a parameter and if I do
client.sendString ( "test") works now like to put this client within the serial receipt.
thank you
