Sming - Open Source framework for high efficiency native ESP8266 development
By hreintke
#37999 Sming is not one-to-one compatible with arduino.
Sming is fully "event based" vs the "loop based" concept from Arduino -> applications are written as callbacks.
As you have seen the conversion from libraries is not too complicated.
Sming has full and out-of-the-box support for http/tcp/ntp/telnet/mqtt IP connectivity, timers, pwm, gpio, json and much more. See more details on the readme of the github repository.
We are currently converting Sming to use the RTOS sdk from espressif.
With that the arduino compatibilty will futher improve.
