I see in your code you write:
if pinaction == "po" then gosub, [pomypin]
But the documentation example for GOSUB AND RETURN simply says:
gosub {label}
Why do you put a comma after gosub? Is it optional? required? shouldn't be there?
Explore... Chat... Share...
