To me this almost seems like an incorrect assumption that data is being added so it is not possible ... How else would anything work right if this were the case there has to be some type of exponging of the data for anything to work in that case unless the data is somehow needed for the serial terminal beats me I am curious to know how this pans out I will keep reading as I am far from knowing but hey cool comment.
Where I buy my ESP8266 boards from... (Banggood)
If I run the following two line program;
timesetup(10,0)
print "Time is " & time("hour:min:sec")
I get the response "Time is 00:00:00"
If I comment out the timesetup line I get the correct response "Time is 09:14:04"
TimeZone.dat and DaylightSavings.dat contain the correct values (10.00 and 0.00), and if I delete them they are recreated correctly.
I would be grateful if someone could check this as my system is still very flaky.
Regards,
Ian.
I believe it was something like 3 seconds or something like that...
delay 3000
Add the line above between time setup and the actual printing of time.
It may have been a longer delay for the life of me I cannot recall maybe even 2 seconds worked... But yes this is normal and was discussed some time back while it is not documented that well you can see discussions about time setup on the forum.
Enjoy!
forlotto
