So this was likely the problem with the website code and tables as well!!!
The fella with the theromostat issues should try the latest version and see how he fairs with his tables!
Where I buy my ESP8266 boards from... (Banggood)
Explore... Chat... Share...
'program to run 3 different colored LED-stripes with different number of blinks and different freqency
'GUI and other stuff removed
cls
maxanzahlblinks =10
anzahlblinksrot = 6 '
delayblinksrot = 20
anzahlblinksgruen = 5
delayblinksgruen = 10
anzahlblinksblau = 4
delayblinksblau = 10
pinblau = 1 'LED
pinrot = 2
pingruen = 0
rotiston=0
blauiston=0
[top]
button "Lass mich blinken!", [blinkMe]
'button "Exit", [getMeOutOfHere]
wait
[blinkMe]
anzahlrot = anzahlblinksrot*2
anzahlblau = anzahlblinksblau*2
serialprintln "delayblinksrot=" & delayblinksrot
serialprintln "anzahlblinksrot=" & anzahlblinksrot
t = millis() 'millisekunden seit boot
do 'immer eine komplette sequenz von maximal 10 blinks*2 sekunden= Dauer 20 sekunden
m = millis()-t 'Millisekunden seit start
zeitscheiberot = int(m/delayblinksrot/100) 'timeslice for red LED
zeitscheibeblau = int(m/delayblinksblau/100)
roton = (zeitscheiberot % 2) 'ON and OFF
blauon = (zeitscheibeblau % 2)
if roton=0 then
if rotiston=0 then 'flag to execute io only one time per cycle
if zeitscheiberot<anzahlrot then
rotiston=1
'io(po,pinrot,1)
end if
end if
' if rotiston=1 then
' rotiston=0
' 'io(po,pinrot,0)
' end if
end if
if blauon=0 then
if blauiston=0 then
if zeitscheibeblau<anzahlblau then
blauiston=1
'io(po,pinblau,0)
end if
end if
if blauiston=1 then
blauiston=0
'io(po,pinblau,1)
end if
end if
serialprintln blauiston & " " & m 'shows approximately every 100ms at the serial monitor cause of delay
delay 100
loop until m>15000 'run 15 seconds
'io(po,pinrot,0)
'io(po,pinblau,1)
print "ENDE"
wait
